Question about Brother HL-2040 Laser Printer
Brother HL-2270DW printer shows offline and won't print
It printed once and then saya offline. Both my computers are wielessly conected to the printer.
Posted by Isa McClain on
  • honey
    honey Jan 26, 2018
    give a call to support (877-690-9305)
Albert Danry
    New Friend:
I had this problem today with my wireless Brother MFC-990CW using Windows 7, and when I went to see what s printing, then printer, it wasn t showing that I had checked the use printer off-line
So, on my pc I went to the start button then chose:
- Computer
- Network
- Double click your printer
- New print drivers will start to install
- Right click the icon that is a copy made of your printer setup
- Set this as your default printer
I was then able to print and my printer didn t show as being off-line anymore. This is a lot easier than having to uninstall and install the printer again using the disc.
Source(s):
https://answers.yahoo.com/question/index?qid=20140422184955AA0dJ7F
Posted on Apr 11, 2016
James Smith
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Follow the steps below to resolve this issue:
STEP A: Verify the Brother machine is powered on and there are no errors
1.If your Brother machine's screen (hereinafter called LCD) is blank, the machine may not be powered on. Check the machine to see if it wakes from sleep mode.
If it does not, then make sure it is plugged into a working socket and any power switches are turned ON.
NOTE: If you are unable to power on the machine, then this solution does not apply. Go to Brother Troubleshoot this hardware issue. 2.Check the LCD for any error messages. An example would be "Paper Jam" or "Ink/Toner Empty". If the LCD shows an error, troubleshoot the error to clear the issue indicated.
STEP B: Make sure the printer is connected to the computer
  • If using a USB cable, make sure the cable is connected to both the printer and computer.
    Try connecting it directly to the computer and not via a hub.
  • If using an ethernet cable, make sure the cable is connected to both the printer and router/access point.
    Print the network configuration page to check the IP address.
  • If using a wireless connection, print the network configuration page to check the IP address.
If the issue continues, go to STEP C.
> STEP C (Windows): Make sure your Brother machine is set as the default printer
> STEP C (macOS): Make sure you are using the correct Printer Driver for the Brother machine
Open the printer folder and make sure there is a check mark on your Brother machine's icon:
(Windows 8 or later)
1.Open the Control Panel. (Click here to see how to open the Control Panel.)
2.Click Hardware and Sound > Devices and Printers.
(Windows 7)
Click Start > Devices and Printers.
If the check mark is not on your Brother machine, right-click the icon for your Brother machine and select Set as default printer.
STEP D (Windows): Delete all printer jobs from the Devices and Printers window
(Windows 7 or later)
Right-click the icon for your Brother machine > See what's printing > Printer > Cancel All Documents.
If Cancel All Documents is gray out like below, click Open As Administrator. Enter the password for an administrator and click Yes.
STEP E (Windows): Check the printer status in the Devices and Printers window
If the printer status is Offline
Right-click the icon for your Brother machine > See what's printing > Printer > Use Printer Offline (removes the checkmark).
If Use Printer Offline is gray out, click Open As Administrator. Enter your administrator password, and then click Yes.
If the printer status is Paused
Right-click the icon for your Brother machine > See what's printing > Printer > Pause Printing (removes the checkmark).
If Pause Printing is gray out, click Open As Administrator. Enter the password for an administrator and click Yes.
STEP F (Windows): If a copy of your Brother machine's icon (For example: Brother -X (Copy 1)) is listed in the Devices and Printers
A copy of your printer with the same printer name may be created if you:
  • Changed the USB port on your computer which is connected to the Brother machine.
  • Installed the same printer driver multiple times.
This may lead to some copies of your printer driver not working correctly. To print, select a printer driver that you know is working.
To check which printer driver is working, do the following:
1.Turn the Brother machine on. If any other machines are connected, only turn the Brother machine on that you want to use.
2.Open the printer folder:
(Windows 7)
Click Start > Device and Printers.
3.Hover the cursor over the printer icon until the printer status pop-up appears.
If the status is Ready, it means the printer driver is working correctly. Select this printer driver when printing.
(Optional) To change the printer name, do the following:
1.Right-click the printer icon.
2.Click Printer Properties.
3.Change the printer name in the Printer Properties window, and click OK.
4.If you always want to print using this printer, right-click the icon of the machine and select Set as default printer. The check mark will appear on the machine's icon and when you next print, this printer driver will be selected automatically.
STEP G (Windows): If the issue still continues...
Check the solution applicable for your case:
(For USB connection)
> Click here to see how to resolve cannot print using my Brother machine on a USB connection.
(For network connection)
> Click here to see how to resolve cannot print using my Brother machine on a network connection.
STEP C (macOS): Make sure you are using the correct Printer Driver for the Brother machine.
1.Select Apple Menu > System Preferences > Print & Scan or Printers & Scanners.
2.Select your Brother machine in the Printers section.
3.Verify which printer driver is used. This can be found next to Kind.
If the AirPrint printer driver is selected, add the CUPS printer driver to your Mac as described below.
If you find CUPS printer driver, the CUPS printer driver is installed correctly.
a.Select Quit System Preferences from the Apple Menu.
b.> Go to STEP D.
c.Select Apple Menu > System Preferences > Print & Scan or Printers & Scanners.
d.Click the + button.
4.Click the Default icon which is located at the top of the dialog box.
5.Select your machine from the Name list.
6.Make sure that "X + CUPS" is selected in the Use list. (Where X is your model name.)
If you cannot find the "X + CUPS", the CUPS printer driver is not installed.
Download the latest Full Driver & Software Package and install it. The installation instructions are available on the download page.
> Click here to download Full Driver & Software Package in the Downloads section.
If Full Driver & Software Package is not available for your models, select CUPS Printer Driver or Printer Driver.
7.Click Add.
8.The printer is now available in the Printers section.
9.Select Quit System Preferences from the Apple Menu.
Posted on Oct 25, 2019
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: printer online then offline
My first solotution was to reinstall the printer as a new printer. But that is uncessary. The fix is as easy as changing the IP address the in Port.
The problem is the the IP address for your wirelss is not static. and when it changes, the printer does not recognize the new IP address. When this occurs. go the the printer folder ( in the control panel) and click on 'add new priter'. Then select 'add a network wirless printer . NO NEED TO INSTALL THE PRINTER...you just want to see the IP address.
Note the IP address.
GO to the printer, click on the right mouse and select 'properties'
Click on Port
You will see the current port already highlighted.
Click on ' configure port' and change the IP address under "printer name or IP address.
Click OK.
Problem solved
Good luck.
DeniseA
Posted on Mar 21, 2009
dmarciante
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
Anonymous
  • 86 Answers
SOURCE: I can not print
You could try to use static ip to remove possible problems with dns retrieving:
  • Set the machine to static ip (Menu -> Network -> WLAN -> Boot Method -> Static).
  • Check the ip number on the machine (Menu -> Network -> WLAN -> IP address)
  • On your PC, go to Control Panel -> Printers
  • Right-click printer, choose Properties
  • Choose Ports and click "Add Port"
  • Double-click on Standard TCP/IP, follow the guide and type in your IP number earlier retrieved.
  • Save settings, press OK and the problem could be solved (if it was due to dns problems).
Also, if it works, you can change the network settings for scanner driver to go to ip address too instead of dns, even if it isn't a problem right now, it could later be.
Posted on Jun 02, 2009
bschilz
Bill Schilz
  • 2049 Answers
SOURCE: Brother HL-4040CN successfully installed but shows offline
I assume it's turned on and connected to the router.
Sometimes with DHCP, the IP address on the printer will change. I end up going into the router table to see what IP addresses are assigned where. Invariably I'll find my network printer has changed. Find the printer and write it down.
In Windows, Go into Printers> choose the Brother and right click to check Properties. Look for Ports and change the IP address as needed. It will come back online.
Posted on Sep 17, 2009
DeadDreamer
  • 254 Answers
SOURCE: I have brother Printer HL
hello
printer becomes offline if it is turn off or the pc not recognized the printer.
solution: check the cable printer, transfer cable printer port to another port in your computer, if the problem still occurs re-install the printer driver.
thank you
Posted on Mar 08, 2011
Says printer error...wont print
Sir/Madam
If Your Brother Printer Not Print Then Please Go To Official Brother Printer Website To Perform Below Step :
The printer status is Offline or Paused For Windows Brother
If your question was not answered, please check...
Or
Still Having Brother Printer Problem then Follow Us For On :
Jan 19, 2014 | Brother HL 2270DW Laser Printer
Can't print from Wordperfect 11 to my new Brother 2270 DW printer
Could it be that you are printing into a file and not to the printer?
Dec 06, 2013 | Brother HL 2270DW Laser Printer
False 'Cannot Print' Warning on Brother HL2270 DW
Hi, as one comment mentioned, you should try configuring the sleep timer, I had the same problem and that did the trick. Those Brother printers can be painful to deal with sometimes :) Btw, if you need the service manual, you can find one here - Brother HL-2270DW manual
Jan 25, 2013 | Brother HL2270DW HL-2270DW Compact...
My HL 2270DW won't stop printing goobldegook. One or so lines on each page, and the printer job does not show in the cue so it can not be cancelled. I can not print any jobs because of this malfun
Has it worked before? Many of these newer printers can print what are called Postscript documents, and you may have a Postscript driver instaled instead of the regular driver, or both and have selected the wrong driver when sending the job ORyou have an internal circuit board that'sgone bad
Jan 07, 2013 | Brother HL 2270DW Laser Printer
Brother HL 3075CW printer is offline and won't print
I am having the same issue. The printer works for a few days, and then the IP address for the printer changes and I cannot print anymore. Any idea as to how to solve that issue?
Oct 21, 2012 | Brother HL-2170W Laser Printer
I just bought a Brother HL-2270DW Laser Printer and it says it can do two sided printing. How do I do that? I don't have a manual - it just came with a Set up Guide. Thank-you.
First you can download the manual here : http://www.iusermanual.com/printer/brother-hl-2270dw-printer-manual.htm
Usually you need to enable DUPLEX option in the printer's managing software...
Jun 18, 2011 | Brother HL 2270DW Laser Printer
When I hook up my printer (ether USB or wireless) the printer immediately prints one blank page and jams halfway through the 2nd. There is nothing on either page, and there are no print jobs in the queue...
You will need to either clean the pickup rollers , or order a service kit to replace them, if not the rollers then it will be a blockage along the paper path, try pushing some nice thick paper along the print path from various positions to see if you can clear it.
Jun 04, 2011 | Brother HL 2270DW Laser Printer
Brother HL-2040 Laser Printer Logo
23,473 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
