Tricity Bendix AW1400W Front Load Washer Logo
Michael Woods Posted on Jun 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tricity bendix 1400w will not start have heard 6 beeps
Machine will not start nor will it fill ...have heard 6 beeps
Level 3:
  • Tricity Bendix Master 17,130 Answers
  • Posted on Jun 28, 2012
Level 3:
Answers
17130
Questions
0
Helped
3631768
Points
52372
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
5 Related Answers
A
Anonymous
  • Posted on Jan 05, 2007
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Anonymous
  • 38 Answers
  • Posted on Aug 26, 2007
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Anonymous
  • 54 Answers
  • Posted on Feb 12, 2008
SOURCE: Tricity Bendix AW1001w
is the door locking if not replace it.
douglas smith
  • 1462 Answers
  • Posted on Aug 09, 2008
SOURCE: Tricity Bendix W/D 1000 fills and drains but drum doesn't turn
check brushes in motor
Ambari
  • 901 Answers
  • Posted on Mar 31, 2010
SOURCE: machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
1helpful
2answers
Machine will fill and turn slowly but will not
Solve Your
I have spent most of the afternoon looking for the float etc. In frustration I upended the machine to look for the inlet hose point, water started pouring out so I put the machine back in the upright position. Now it's filling with water and working again. Maybe there was something in the hose which became free with upending it. Not sure, but worth a try, it worked for me!
4helpful
2answers
Tricity Bendix AW1002W
my washing machine is making funny noise before it starts and today it will not start at all just the funny noise
8helpful
2answers
Tricity Bendix DH101 dishwasher
my tricity bendix dh101 will not fill up with water what could be the problem
My tricity bendix washing machine flashing and beeping end light
Top Tricity Bendix Washing Machines Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
