Holes are in the top corner of the canvas about 2 inches from where the front screen room is attached
SOURCE: problems putting a tent up lol please help if poss
I've got the same tent if you want to send me your address to [email protected] I will photocopy my instructions leaflet and either post it to you.
Regards
Simon
SOURCE: I have a bad zipper on my tent trailer. The
You can do this. Another possibility is to have an upholsterer look at it, or even a sailmaker, if you have one close.
Best regards, --W/D--
SOURCE: square tent with 2 types gazebo poles, varenda, 2 side windows
the 2 longest of the poles go in an x over the center of the tent and the 2 shorter ones go arch to the sides. http://www.wenzelco.com/details.aspx?NavID=412
shows a picture very similar to your tent. If you go to image 2 it shows it with out the fly. now if you got 2 sets of 4 poles, 2 long and 2 short, and one set is all aluminum, then I would go with the aluminum set. It is less likely to collapse in high winds.
SOURCE: I have a Thermos
I have one of these tents, here is how you operate it. When you pull down to set the tent, pull down on the larger fatter end. When releasing, pull down on the skinny side. I use the canvas bag to pull it down. That makes it easier on the hand. Or use work gloves.
Good luck
J
SOURCE: A straight right resulted in a two inch split on
A auto weather strip glue works well but watch the color if looks matter
Testimonial: "Thank you for the advice, Bob is not bothered by the colour and neither am I. I will give this a shot."
Finding the source of a leak in your waterbed may not always
be easy. Some punctures can be very
small (some even the size of a pin), making it difficult to find. The best place to start is by wiping the
entire mattress dry. Before going any
further, make sure that your heater is unplugged. First try to locate the leak without draining
the bed. Place paper towels around the
perimeter of your bed as well as around the corners and bottom seams. Then lay on your bed for a minute or two to
apply some pressure. Check the paper you
laid down to help diagnose the location of the leak. If this method does not work, you may have to
drain your mattress. Refill the mattress
with air and sit on it. Using a spray
bottle filled with water and dish soap spray the suspected areas. You will see bubbles appear in the area where
the hole is located.
Once you have located the location of the leak, you can now
repair it. You will need a vinyl repair
kit - most waterbed mattresses are sold with one, if not I will leave you a
link so that you can purchase one online.
For a small pin-size hole, you will only need a very small patch. Try to cut either a round/oval shaped patch
as corners usually lift. Apply some
adhesive to both the patch and the mattress and attach. You should let the patch dry for a minimum of
two hours before putting any pressure on it.
http://www.waterbedoutlet.com/Waterbed-Vinyl-Repair-Kit-p/wba-blu597300vrk.htm
http://www.amazon.com/Blue-Magic-Waterbed-Vinyl-Repair/dp/B004J6NFYY
Here
are a couple of links to places that specialize in canvas tents. http://www.canvastents.co.za/
Or http://www.canvashome.com/
