Question about Nokia 2600
Not charging 2600 phone is not chargin
Posted by k.noor mohammed on
Jordan Raingam
  • Nokia Master
  • 2,148 Answers
Hi You mean that when you insert charger it showed "Not charging" ? First insert another battery (it should not be BL-5Cb).If the problem persist you need to change a components.If you think you can do it follow the given link 2600 not charging,otherwise contact nearest mobile repairing shop.Good luck
Posted on Jun 28, 2012
My phone does not want to charge wats wrong
try with other charger.. if nt working den make sure d chargin pins on phone s proper... its a small hardware issue.. open d phone n make sure d charging socket on circuit has no damage... ( switch off ur phone n try charging too )
Jan 03, 2011 | Samsung Highlight Cell Phone
2600 charging pro
What do you mean by 2600 charging pro? Are you having a problem charging the phone? If you do, the first thing that you need to do is to borrow a known working charger to see if the problem is the charger or the battery. If same problem occur, try to use different (known working) battery and see if the battery will charge.
If the different battery charged, then you need to replace the old one. But if not, then the problem is that there are some internal components that needs to be replaced.
Bringing the phone to the nearest Nokia care center would be the best thing to do, after isolating the problem.
Thank you and good luck!
Jun 17, 2010 | Nokia 2600
Not charging
Not Charging:
You either have a bad battery - cheap to replace and test.
Or you have a bad charger - try a different one.
Or the phone is going bad and just won't hold a charge -and then you will have to replace the phone..
Mar 25, 2009 | Nokia 6030 Cellular Phone
Samsung B100 chargin problem,not charged.
charging problem.not charged.
Jan 25, 2009 | Cell Phones
Can't Charge!!
Try another charger. I broke the plastic that locked into the phone on my car charger and had problems charging. The phone is very finicky about the contacts. Had to replace charger.
May 28, 2007 | Sony Ericsson T610
Nokia 2600 Logo
271 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
