I have a verizon fios remote control and do not have the original remote for the tv.
SOURCE: toshiba pip
Try silver philips universal remote control ( 2 in one) $12 Dlls., get code search settings .........That's work !!!. I hope this work thank you
SOURCE: Remote optic
I've heard where other people have replaced thier box and remote several times. FIOS is in denial and will offer bogus solutions even when they know they have a compatability issue.
SOURCE: Toshiba CF32H50-no control from remote
Could be the remote does not operate on the correct frequency, but also may be the IR reciever sensor inside the TV, best bet is to bring your remote to a pawn shop and try it on a set there (they sell older model sets look till you find one like yours). once you determine the remote is OK, check the IR sensor for bad solder connection or replace it by soldering a new one in. Also some Toshibas develop micro CPU issue (the computer IC), another thing you can try is cleaning the main board control area with electrical cleaner residue can load down the control circuits but then the buttons would also malfunction.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: Toshiba 32A43 - suddenly stopped
hi
this kind of problem is usely comming from one of the front panel button if so the set will show the menu intermitently and no action from the remote. What i use to do i replace
all of the tack switches 6or 7 but i would suggest to consult your local tv repair shop if
you do not have some kind of experience.
