SOURCE: Cant get my computer to
Check audio drivers ..I re-installed my Audio drivers and it worked fine for me ...
SOURCE: problems with samson g track usb mic
sounds like your recording volume is too high, and its "clipping"
SOURCE: Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:
select a voice track to record into
make sure the Track Info window is open (blue i button in lower right region of screen)
at the bottom of the Track Info window you will find Input Source:
Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
SOURCE: static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
SOURCE: Samson G-Track mic does not work with garageband effects
Look man just use the input as a way for your pre-amp's to plug in.... you don't want any of those built in guitar effects anyways... You just need a good multi pedal.. There are many good recording Pre-amps out there that work great and are fully adjustable for easy recording.. You can do what you want but, I think you will like the sound of pre-amp effects pedals in your computer set up....
Thats just a tip
