Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
I have a hcp4363wx/xaa and I would like to know how to reset it to factory settings?
I lost channels and I need them back so I would like to reset my tv.
Posted by Deanna Mulgrave on
German Gonzalez
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
The User manual explain this case.
Posted on Jun 30, 2012
3 Related Answers
ladywinn
ladywinn
  • 5138 Answers
SOURCE: Samsung HCP4363WX/XAA
Was wondering if you got set fixed yet? STK-392-180s are the ics I use when repairing convergence.Replace both chips.
Posted on Mar 31, 2008
Anonymous
SOURCE: Samsung LCD TV HCP4363WX/XAA Black screen no sound.
check out the link below ... sounds like a similar problem:
http://www.dslreports.com/forum/r20889230-Samsung-LCD-TV-No-Picture-but-has-Sound
Posted on Sep 06, 2008
Ecollier2012
Edward
  • 3459 Answers
SOURCE: i have a samsung HCP4363wx/xaa rear projection tv,
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Posted on Sep 24, 2010
Does anybody know how to set a 32 inch Sony Bravia back to factory reset without remote
yes manually you can set press menu button then go to av setup & select factory setting from using vol+ & vol- with channel + & channel- buttons
Jun 21, 2015 | Sony Televison & Video
How do I reset to the factory settings
If using a box it has SAP also and can be removed there if coming from the box settings.
Jun 14, 2012 | Televison & Video
Lost password,how do I change password
ALL YOU CAN DO IS TO RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory setting from the reset button on the back side of the router. Use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
HOPE IT HELPS...Let me know if you need any further assistance
CreativeTECH
Nov 13, 2010 | NetGear WGR614 Router
I have a samsung HCP4363wx/xaa rear projection tv, and everything on all chanels looks like its always in 3-D, text is unreadable, any ideas what might b wrong ??
Sep 24, 2010 | Samsung HC-P4241W 42" Rear Projection...
Starview channels missing
you should not have factory reset when you lose a chnl delete the chnl then rescan you never need to factory reset you lose the flash or newest update you had installed reflash your box and delete the chnls that are scrambled only and then rescan
Feb 20, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Aug 21, 2008 | Samsung HC-P4241W 42" Rear Projection...
Jan 31, 2008 | Samsung HC-P4241W 42" Rear Projection...
Missing manual for - sharp VC-A560 VHS
I lost my manual and the biggest issue of getting this set up is getting the vcr to the channel you need for play back either channel 3 or channel 4. To change the channel you hold the power button and the tv/vrc button at the same time till you get the channel you want. Three flashing lights is channel three, four flashing lights is channel 4. every time the power goes out mine resets to channel 3 and will not play videos until I reset to channel 4. Hope that helps.
May 24, 2007 | Sharp VC-A560U VHS VCR
Open Questions:
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
242 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
