Question about Ricoh IS760D Flatbed Scanner
Ricoh IS760D won't work with Windows 7 64-bit
I work for a company that has a Ricoh IS760D Color Scanner. We have recently upgraded to Windows 7 64-bit. The drivers do not seem to work.
Posted by Ian Overholt on
Danie
    New Friend:
    Problem Solver:
Software (driver) can be found at driverupdate us.
Take a look... I hope this was helpful.
Cheers
Posted on Dec 21, 2014
5 Related Answers
Anonymous
  • 121 Answers
SOURCE: Ricoh IS760D
go into your properties by right clicking on the icon or goto my computer, look for your printer and right click to find property setttings.. you should be able to adjust your colors from one of the tabs that appear..d
Posted on Feb 22, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Ricoh IS760D Functional Problem SC4020
Unfortunately, the message indicates that the internal startup tests have failed. If this unit is just past the warranty period, I would contact the manufacturer anyway and complain. No unit should fail that close to the period conclusion especially with little to no use. It is possible that a brown-out may have damaged the internal logic. Only a service tech for the company could tell you that. The blinking lights are an indication of the problem found. Report that to the company as well.
Good luck. Keep us posted.
Dan
Posted on Mar 18, 2008
Anonymous
  • 12 Answers
SOURCE: richo color scanner is760d don't have option auto feeder
This scanner can be controlled by PixEdit so you may scan any amount of sheets. Even easy continue scanning to one document when not enough space in the ADF for the hold stack
Posted on Aug 21, 2009
  • 6185 Answers
SOURCE: I can't get my Ricoh
Microsoft drivers and installers have changed over time. The ISO1 drivers for XP are available here: http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/is01/is01en.htm . Click on the down arrow to download the one for XP and then double click on the exe file.
I hope this helps.
(NT or Win2K drivers can work under XP at times; Win95 drivers are less likely to work even in the compatibility mode.)
Posted on Nov 25, 2010
Stephen baynes
  • 394 Answers
SOURCE: I am trying to hook
Hi, I am steve, lets get you some help.
Your scanner only supports TWAIN and ISIS. Whilst you can use the scanner from Windows without any problem you can only control it from an application that supports TWAIN or ISIS.
As you have already discovered your application wants to use WIA - you cannot do this automatically. You may want to check whether your application supports either a TWAIN or an ISIS interface (I would expect it to). This is a long running issue with scanner devices.
You could use the Ricoh software and any TWAIN/ISIS enabled software to import the scans then upload the captured file into the application.
Sorry it can't be simpler than that.
Posted on Jan 17, 2011
Dan
Mar 18, 2008 | Ricoh IS760D Flatbed Scanner
We have a network ricoh aficio mp 1600 pcl printer we recently upgraded to windows 7 printer and copier are working ok but scanner is not working is there a problem with the scanner driver for windows 7
please go to www.ricoh.com and instal the scanner drivers of windows-7 other wise you can instal the scan to folder which dos not required any drivers or you can install scan to mail this also does not required any drivers - thanks
Mar 10, 2011 | Ricoh Aficio MP 1600L Black and White...
Black line on right when scanning adf - have cleaned the machine dont know what else to do
If line appear in to your scanner pic no repair for that but is only when you print just clean the toner.
scanner Lents cant be change
Dec 17, 2010 | Ricoh IS760D Flatbed Scanner
Scannning too slowly
Increasing the default resolution setting, would slow the scanner down, and also increase file sizes dramatically
Feb 18, 2009 | Ricoh IS760D Flatbed Scanner
Richo color scanner is760d don't have option auto feeder
Dec 08, 2008 | Ricoh IS760D Flatbed Scanner
Kodak i260 scanner wont work on vista
This is a non Vista compatable product.
It may run on Windows Vista 32bit Business though.
May 05, 2008 | Kodak i260 Duplex Color Scanner
Ricoh IS760D
Feb 22, 2008 | Ricoh IS760D Flatbed Scanner
Ricoh IS760D Flatbed Scanner Logo
1,880 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
