Question about Sanyo MM-8300
Sim card location sprint sanyo mm-8300 - Sanyo MM-8300
Posted by scott on
3 Related Answers
truck1
Jeffrey Thomas
  • 24 Answers
SOURCE: Sanyo mm-8300
Call Sprint tech support at 1-888-211-4727 see if they can help.
Posted on Jan 30, 2008
Anonymous
SOURCE: katana II by sanyo on sprint network
Unfortunately it will not work. TMobile uses GSM technology while Sprint is on CDMA.
Posted on Apr 12, 2008
Anonymous
SOURCE: to unlock code no. of sanyo mm-8300
use cdma workshop
Posted on May 26, 2008
Sprint told me to remove the SIM card from a Sanyo Pro that has each contact showing up twice. I can't find the SIM card.
The Sanyo PRO-700 is like all Sprint phones and uses the CMDA network so no Sim card is used. You can take the phone to the Sprint store and have the clerk's use the transfer machine and that should delete the duplicate entries.
Mar 07, 2011 | Sanyo PRO-700 Cellular Phone
Phone got wet, need to get sim card out?! Or clean it. Thank you, Mark Coffey
Hello!
Make sure the phone is completely dry before you turn it back on . Take out the battery and the SIM card and completely dry them off - Especially on the electronic contacts.
Heres a trick: If you have a food dehydrator leave the phone in it for a couple of hours. This will remove the moisture from the phone and the water won't short circuit the phone.
If you have trouble locating your SIM card, it is under your battery and should slide right out with no trouble. If you do have trouble, please comment on the question and we can try something else!
Cheers!
Feedback is appreciated!
Dec 30, 2009 | Sanyo MM-8300
Sim Card on my Katana 2 phone
If both your phones are locked to Sprint as your service provider, no problem, just transfer the sim card from one phone to the other.
Jul 24, 2009 | Sanyo Katana® II Cellular Phone
Where is the SIM Card?
i have a sanyo katana lx and there is no simcard. it really depends on what carriar the phone is for. if its for sprint it wont have one. t-mobile still uses sim cards.
May 06, 2009 | Sanyo Katana LX Cell Phone
SPRINT SANYO PRO 700
Hey! I just got the PRO 700. IT DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
Apr 09, 2009 | Sanyo PRO-700 Cellular Phone
Sanyo MM-8300: ALL the keypads are frozen and won't work. Any solutions?
One thing you could test for is a thermal-fault in the phone's circuitry. To do this, you put your phone in the fridge over-night then, turn it on the next day and try the keypads while it's still cold from the fridge. If that doesn't help and you're brave enough to venture into the inner-workings of your phone to attempt repair/cleaning, you can read my post here- keys won't work on sanyo mm 8300 phone.
Hope this helps, TechnoWolfy.
Apr 20, 2008 | Sanyo MM-8300
Katana II by sanyo on sprint network
Mar 31, 2008 | Sanyo Katana SCP-6600 Cellular Phone
To unlock code no. of sanyo mm-8300
call *2 - sometimes the rep will help you over the phone and other times they will tell you to take it in to the store to have it reset.
Mar 14, 2008 | Sanyo MM-8300
Changing language on sanyo MM 8300
hi there
you can change back to default english by pressing shortcut keys.
press menu/ok
select settings
press options(right softkey)
then select language
now slect english.
hope this helps.
Feb 07, 2008 | Sanyo MM-8300
Sanyo mm-8300
Nov 30, 2007 | Sanyo SCP-3100 Cellular Phone
Cell Phones Logo
Top Sanyo Cell Phones Experts
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Resolution IT Dubai
Resolution IT Dubai
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
