Question about Pramac Storm 5000 Watt Generator
Pramac storm 5000 choke hidden
Am I missing a part? The choke only works by pushing on it directly which is hard to do while pulling the starter cord. The lever with the rabbit and the turtle does'nt move at all, so I'm afraid some linkage may be broken or missing. Any advice?
Posted by spiessdg on
I AM NOT ABLE TO START A BRAND NEW STRAMM GENERATOR
first off---- have you put oil in the sump to the correct level there is a low oil lever switch which will not allow spark if the oil is not there or is too low to safely run the engine
next fill the tank with the correct type of fuel
turn on the fuel tap under the tank
put the choke lever pull in the choke position
switch on the ignition switch
pull the starter cord
when it fires push in or remove the choke action
basically read the user manual that came with the genset
Jul 08, 2016 | Cars & Trucks
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
How can I free both the stuck choke pullout lever and the on/off switch on my Poulan Pro 18" chainsaw? I tried using the start handle pull to rotate the engine, which turns normally, but switches are still...
This is a carburetor linkage problem and pulling engine though with the starter will not have any effect.
Check all the linkage at the carburetor for problems. Also try pulling the throttle trigger and may sure it operating the carburetor.
Aug 14, 2014 | Poulan Garden
I have a craftsman 20 OHV Intek Plus riding mower on the throttle lever is also the choke is above the rabbit and my wife got on the mower and wanted to go faster and pushed the throttle lever all the way...
Hi, it may have saturated the air filter with fuel. Try it without the filter, if ok dry or replace the filter. Hope this helps, regards Phil.
Aug 13, 2011 | Garden
Cant remember how to start my g100 wacker. Can pull the starter cord but forget where the little knobs need to be turned to
I am not familiar with your model but general rules are as follows. 1 - make sure that the gas'oil mixture is the right ratio and that the fuel is not stale. 2 - Depress the little rubber primer bulb 4-6 times, or until yor see little bubbles through the bulb. 3 - Rotate the choke lever to Full and pull the starter cord until the engine tries to start. 4 - Rotate the chole lever to Half and pull the starter cord until the engine starts.5 - After the engine warms up, rotate the choke lever to Run or Open so that the engine runs smoothly.
Jul 01, 2011 | Garden
My Fs 45 will not start. I am unsure if i am even starting it properly but i think i am. It was purchased over christmas and has only been used twice. There is fuel in it and was working fine the last...
The fuel could be stale. I would empty the fuel tank and put fresh fuel in it. Make sure the unit is in the ON position. On the handle there is a switch. ( I is ignition (to start) and O is off (to kill the unit)). Then pump the primer bulb a few times to make sure there is no air in the fuel lines. Then move the choke lever up into the choke position. Pull the starter cord no more than about five times, it should try to start. Then move the choke lever down, into the off choke position. You should pull the cord a couple of more times and it should start right up. If you have put the choke lever in the on position and pulled it a few times it could be flooded. To clear out the cylinder and get the unit running at this point. Turn the choke to the off position and pull the unit a few times. Depending on how flooded the unit is it could take quite a few pulls.
Apr 03, 2011 | Garden
I have been trying to turn on my chain saw. Ive pulled the handle back by the trigger gave a few pull on the rope. then i pushed the button in on the side also the push the button back in by the trigger...
The chainbrake should be activated when starting the chain saw. Activate the chain brakeby pushing the front hand guard forwards.b>Cold engine Start position, 1: Set the start/stop switch in the choke position by pulling thered control outward - upward.Decompression valve: Press the valve to reduce the pressure in the cylinder and makestarting easier. Once the machine has started the valve will automaticallyreturn to its original setting.Air purge: Press the air purge diaphragm repeatedly until fuel fills thediaphragm (at least 6 times). The diaphragm need not be completely filled.Grip the front handle with yourleft hand. Hold the chain saw on the ground by placing your right foot throughthe rear handle.Pull the starter handle, 4: Pull the starter handle with your right hand and pull out thestarter cord slowly until you feel a resistance (as the starter pawls engage)then pull firmly and rapidly until the engine fires.Push down the red choke control: As soon as the engine fires which can be heard through a"puff" sound, push down on the red choke control.Pull the starter handle (6): Keep on pulling the cord powerfully until the engine starts.
Nov 18, 2010 | Husqvarna 450 e-series 18" Chain Saw
How to start a Husqvarna 445?
Set choke to full on. To do this depress throttle all the way down and set choke lever to on. Pull starter rapidly until saw fires . Once it has fired set to start and pull starter cord until it starts. If it doesn't start in ten - twelve pulls,reset choke for two or three pulls,then switch back to start. Pull starter cord until it starts. When it starts it wii be at full R.P.Ms. Let run for twenty to thirty seconds. then move switch to run. Hope his helps, Thanks
Nov 18, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
Choke stuck in closed position1984 VW Rabbit
Hi !
Firstly see if the choke wire is stuck from inside itself or from the Carburetor side.
To check this you will need to pull - push the small knob on the Carburetor where the choke wire is attached. If it moves freely then the choke wire is stuck in itself.
If it is stuck from the Carburetor side then you could use a spray like WD40 to free the leaver.
Else disengage the wire from the Carburetor and pull the wire out from the inside. Clean the wire and lubricate it by using any good lubricant (engine oil works the best). Then slowly push the cable back and fasten the wire back with the Carburetor.
Regards
Berry.
Feb 01, 2010 | 1984 Volkswagen Rabbit
It wont start
First, make sure that the gas mixture is correct (gas and oil mixed in the right proportion). Next, press the primer bulb 3-4 times, turn the choke lever on to Full Choke, and pull the starter cord until the engine seems like to wants to start, but dies. Next, switch the choke lever to Half Choke and start the gas trimmer, giving it gas by pulling on the trigger. Once it has warmed up fully, you may be able to reduce the Half Choke to No Choke, although my 20+ years of experience with dozens and dozens of models tells me that many trimmers run better, although smoking slightly, when you keep them at Half Choke. One last tip, when pulling the cord, try pushing the trimmer away from you with the opposite hand at the exact same time that you are pulling the starter cord--the equal and opposite push-pull technique may sound like something from karate (and it is, in a way), but it is really helpful when trying to start trimmers. Best of luck, Bill
PS: Check you owner's manual (at home or online) for the proper gas/oil mixture. Empty any old gas out and replace the spark plug, if required.
Oct 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Pramac Storm 5000 Watt Generator Logo
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Robert Wooley
Robert Wooley
Ngoro
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
