Using Novastor netbackup 11sp1. I moved from a win2k server, drive attached to a netware server, to a small business 11 server with the drive attached, and went from one to two tapes needed. Software and Hardware compression are selected Compression is .8:1 on the MS server and 1:1 on the netware server.?????? ThaNKS FOR YOUR HELP
You never actually asked question.
is this a tape space issue, (compression not up to par)
what?
why not ask at HPE. its an enterprise system Business.
why ask in the toy section here./. and not real HP
here is real HP. (i have Proliant servers)
https://www.hpe.com/us/en/support.html
ask on the real HPE forum first. bet wise do that and NOT HERE.
create an account (free)
the look on the hpe forum
here.
see all those other wise users asking in the right place, yes.
https://community.hpe.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=true&q=tape+Ultrium+448
SOURCE: Ultrium LTO 3 Tape Autoloader Error
what software are you using? try not backing up the system state to see if that changes anything?
SOURCE: How to configure or enable
The L&TT support ticket contains drive configuration
information such as whether hardware data compression is enabled or not.
Use L&TT to pull the ticket then look in the
Drive->Drive Configuration section for details.
Here's an example:
|__ Drive
||__ Data compression : Enabled
||__ Current block size : Not available
||__ Detect WORM tampering : WORM not supported
||__ Reads after WORM tampering : WORM not supported
||__ Media removal (software controlled) :
Allowed
If data compression is not enabled then it is likely that
it has been turned off by the backup application. Check the options in your
application to ensure that software compression (done by the server) is turned
off and hardware compression (done by the drive) is turned on.
Data compression can be turned on in the drive by
NetBackup usersCaution NetBackup
will turn off hardware compression in the drive at the end of each backup, so
when you look at it with Library and Tape Tools it will be off. This is actually normal for NetBackup, so please check
the configuration of NetBackup to make sure that compression is configured
correctly. In this case see 'Measure Compression Ratio' (go back one level) as
that will show whether compression has been in operation in the drive.
Click here to download the free L&TT
utility (www.hp.com/support/tapetools) - this will also access the L&TT user guide
Use the L&TT FAQ to find out how to pull a
ticket.
Click here for the L&TT FAQ. (www.hp.com/support/lttfaq) Look for
How do I generate a support ticket? in the contents.
