Hi there:
Don't confuse this steady pulsing of the Check Engine Light light (usually one or more flashes per second) with a flicker (see above). The Check Engine Light may stay on steadily or it may flash when the vehicle is accelerated. This is very serious. There is a severe failure of the emission control system that is causing the engine to misfire to the point that the catalytic converter is damaged each time the Check Engine Light flashes. It may mean that the catalytic converter is overheating to the point that it will glow red or, in extreme cases, start a fire on the underside of the vehicle. Immediately pull over to a safe place and have your vehicle towed to an automotive diagnostician for repair. Vehicles can be severely damaged and even destroyed by fire if this condition is ignored for too long.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
SOURCE: 1999 suzuki swift stalling problem
could be a sticking idle air control valve... a little cylinder on the side of your throttle body.. it helps control your idling air fuel ratio.. this goes bad could cause your problems... also easy for you to replace... normally 2 small bolts and a harness.. usually run about 35-85 dollars.. check price and if it's about 35 or so.. i'd go ahead and change it anyways.. 9 years it's probly due.. :D
SOURCE: suzuki liana - exactly the same problem
is the engine going into the red zone in the temp gauge?? a/c will cause an extra load on your engine causing it to run hotter.
SOURCE: Suzuki Vitara V6, MAF sensor, white smoke.
i have a simialer problem but i was getting neat fuel out the exhaust as well . i removed the engine because id got a replacement then stripped the old one and as i thought it was a valve timing problem.looking at the engine from the front the cams on the left bank had jumped one tooth out of time so fuel was not being burnt and coming straight through the exhaust.strangely it didnt seem to have a big missfire and idling and smoke got worse when warm.
