Question about iLO Televison & Video
ILO PDP4210EA1. on startup the picture shows up a few pixels at a time. 5-10 per second at first (across entire screen) then faster the longer it is on. Had a samsung with caps issue before so it was first place I looked. Replaced some bulging caps but no luck (needed to be replaced neways so no worries) Looked deeper. The screen comes up at normal voltages but the color is WAY off. Entire screen has yellow tint and after dark area turns to bright area it takes a while for the pixels to show up. I found out that adjusting voltages with VR1 and VR2 in the right combination the color comes back to almost normal but pixels still show up slow after black scenes. Seemed faster though. After all was said and done, Vs was decreased to 165 (185 is recommended) and Va was decreased to 68. That was best picture i could get but still had issue with slow to display pixels. Also getting no sound. At first I assumed that was a separate issue but not so sure now. any help would be appreciated. Hope thats enough detail to narrow it down a bit.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Mar 06, 2017
SOURCE: Ilo plasma PDP4210EA1 turns on & off
I had the same problem, i took it to a tv repair shop and the said it would be 3-$400 to fix so i just bought a new one but the repair man said the the main board the one with all the inputs and the power supply were bad. U can buy the main board for about $150 and fix it ur self... bth the power supply also cost about $150 as well but i would replace the main board first and see if that fixes ur prob
Posted on Jul 10, 2010
Oct 10, 2014 | Televison & Video
Mar 11, 2010 | Televison & Video
Sep 13, 2009 | Televison & Video
Aug 20, 2009 | iLO Televison & Video
Mar 29, 2009 | iLO V27DMBX Television
May 06, 2008 | iLO 3200 32 in. LCD Television
Jan 22, 2008 | iLO 3200 32 in. LCD Television
Jan 10, 2008 | iLO 3200 32 in. LCD Television
57 people viewed this question
Edited description. Problem posted multiple times. I apologize for that. It kept saying it didnt post.
