I have an older freestanding firplace and also a fireplace insert from the early1990's and need instructions on how to light them for the new purchaser of the house. The freestanding lights in reverse of the insert. Please help with the lighting of the Insta-flame models FSDV30 and FS30 as well as an Insta-flame gas insert from the same time.
Google make and model number you should find a manual you can down load in a pdf .
Posted on Oct 15, 2017
SOURCE: Need Instructions to use Fireplace Gas Logs
There should be a set of metal cards attached inside the fireplace.
First you should read everything there.
I know you have to first light the pilot light.
And then there should be a wall switch.
The problem I have currently is that it won't stay lit when the artificial logs are there.
Posted on Nov 23, 2008
SOURCE: My husband and I recently purchased a house that
Remove the small copper colores tubing going from the gas valve to the pilot assembly. Take it to a good hardware store that sells heaters and ask them for a new one.It is called a thermocouple.
Posted on Nov 18, 2009
SOURCE: How to start a gas fire-place
Hi remove bottom cover you will see black knob with off pilot and on , turn knob to pilot push in and hold in press igntion button untill pilot lights hold knob in for 30 secs then release if pilot stays on turn to on postion if not try again ,
Posted on Mar 02, 2010
SOURCE: My Dimplex freestanding electric fireplace, model
Heater keeps turning off and on every few seconds
Posted on Jan 06, 2011
SOURCE: I have an Insta Flame Canadian Fireplace
sounds as though you need to get the thermocouple(copper wire that sits in the pilot flame) replaced, check first to make sure it is tight at the gas valve end, as they can loosen over time due to expansion and contraction.
Posted on Sep 07, 2011
