Most likely your LCD panels are going out and there is light leak even on 'black' for specific colors. Depends on what kind of projector and model, but I'd replace it. Sounds like it has surpassed its useful life.
I believe it's Tide, I could be wrong, but one of the major brands has
a detergent that helps to keep colors from fading. Also, don't wash them in hot water. The new detergents work just as well in cold water as they do in hot. If you can line dry them, during the day when they can get a breeze, without being in the sun, that might help keep your colors from bleaching out. If the sheets are from your sons bed, you might think about getting some of those pads like the hospital uses. You know the blue ones that they always put under you on the bed. They make some that are pretty big. I would check at a Walgreens or CVS. They should carry them.
you need to leave it on longer. Red fades quickly try using joico cuticle seal after coloring . after coloring try to just rinse out color, don't use shampoo spray the cuticle sealer on the hair and don't wash hair for 2 days..it should keep it from fading so quickly.
Please elaborate on the color not working: 1.Is the picture clear just the color shift is off, or is the picture like watching a black&white Tv? 2.If the colors are just faded, non-contrasting, come and go, go into the programming section and reset adjustments to achieve the desired picture. 3. For colors that fade in and out ( come and go ) absent any information as to the source ( cable, antenna, satellite ) check all source connections, disconnect and reconnect while keeping a an eye out for loose, damaged, or dirty/corroded connections. 4. If determined that that the television does have a component fault, I question the mother board designation as these units have several compartmentalized card/boards. Replacement board availability and location ( as I do not know your location ) is available from :
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
