Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
How to convert from 637R pump to 635T pump? The inlet & outlet opening of the pool are too small
Posted by Melanie on
Katrina Flores
    New Friend:
Hi I have a 637r pump that had no hoses when the pool was given to me so I was just gonna buy a 635t pump that has everything included for 50$ bucks can I use that pump in replace of a 637r pump?
Posted on May 23, 2020
4 Related Answers
Anonymous
  • 76 Answers
SOURCE: I have an intex 15 x 48 pool. The old pump wasnt
check the intex site for adapters and other parts you might need.
I don't think you should buy new pool .
Posted on Jul 15, 2009
nlc0
Nicole Clevinger
  • 3 Answers
SOURCE: New Intex FP621 4000 Pool Pump Noisy
I have a 16 x 48 intex pool with the 1inch inlet and outlet. I purchased the intex 4000 pump. The attachments are too big for the inlet and outlet so i then purchased the adapters. The plungers are very noisy and allow air to get into the pump. I removed them and hooked the hoses up to the adapters directly. That worked as long as the adapters were new. This year the seal comes loose and allows air to get into the pump. I even tried allowing the top nut to be loose to allow air to escape. This year nothing works. The pump is just too strong for the holes. I was considering cutting the holes bigger and glueing seals on there but i was concerned about creating weak spots in the pool. I am tired of spending money on it so i did the redneck thing. I can say that because well, you might consider me one. I took the inlet hose off the connector and plugged the hole with one of those little black things. I took the hose and run it up through the hole in between the liner and the poles and down into the pool. If you run it over the top it will not work correctly. Take the hose and tie them together between the two sides as best you can to keep the hose in the pool. If you look at the smaller intex pools that dont have holes, that is how they have the pump hooked to the pool. VOILA! You have an airtight inlet to the pump. You do not need to do that to the outlet because its not sucking water its just pushing it. So, just hook the hose up as you wish. When you need to clean the filter, I put wash clothes in the hoses to plug them and voila. No air gets into the filter. Done! It is actually keeping my pool clean this year. Also, i purchased one of those aqua vacuums and it does work great for this pool. Once you get the big stuff, sweep it with a pool broom and the filter will do its job. You can vacuum these pools with the filter type pumps. Next time, i will purchase a sand filter and be done with it. Happy swimming with less work.
Posted on May 22, 2010
avionik99
  • 27 Answers
SOURCE: what chemicals do I use
You will need a test kit to maintain the levels correctly. But I just filled a 16ft round (5000 gals) and use 6ea 1 inch hth tablets every 2 days
Posted on Jun 25, 2010
Mike
  • 4376 Answers
SOURCE: hi, we have a intex
be sure the pump is turned off before you try.
Posted on Sep 27, 2010
What would be the best automatic pool cleaner for intex 18 x 48 easy set
try to get the vacuum that works with the garden hose they work ok for the small pools
Sep 09, 2014 | Intex 18 ft x 48" Easy Set Inflatable...
Hose connections from pump to filter etc
what are you asking?
do you want to know how to plumb the individual pieces of equipment?
If so, skimmer port at the pool will go into the suction port of the pump, the port directly into the hair & lint pot.
discharge off the top of the pump will go into the Inlet of the filter valve, then the outlet of the filter will go to either a heater inlet port then outlet of the heater to the pool return inlet ports. If no heater, then from filter outlet directly to the pool return inlet fitting.
Good luck
Jul 10, 2014 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
How do I hook the pool to the filter and then to the pump
The outlet from the skimmer on the pool goes to the pump inlet (center part of the pump). The pump outlet goes to the filter inlet. The filter outlet goes to the return to the pool.
Jul 04, 2010 | Hayward Pro Series 18" Above Ground Pool...
Which tube takes water from pool to pump and which tube puts water back in on the model 633
The outlet from the skimmer goes to the pump inlet (center) the pump outlet goes to the filter inlet. The filter inlet goes to the return to the pool.
Jul 03, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
Low flow indicator on
  1. Plug your inlet and outlet openings so that you can do the next steps
  2. Assuming you have checked your outlet for blockage (skimmer, screen, etc.) take the hose off the end of the chlorinator (goes to the pool inlet) and check the elements for buildup. If all clear
  3. Take the hose off the pump inlet (comes from the pool outlet) and check for hair, grass, etc. clogging the inlet.
Jun 28, 2010 | Intex Automatic Salt Water System for ...
Which hose goes where when hooking the pump up to the pool?
The outlet from the skimmer goes to the pump inlet the pump outlet goes to the filter inlet the filter outlet returns to the pool
Jun 19, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Thomas Perkins
Thomas Perkins
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
