Razor USA Razor Pocket Mod Electric Scooter Logo
thecoz Posted on Jun 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Razor Bella scooter problem
I recently replaced the "bulging" batteries. The new ones are fully charged according to the voltmeter. With the charger plugged in, the on off switch is lit, pressing the throttle makes a one click sound, but no wheel turning. As soon as I unplug the charger, the on off switch light fades away and goes dark. Then nothing...any suggestions ? I don't think it's the batteries, possible the control module ?
Adam Fjeld
Level 3:
Genius:
  • Razor USA Master 1,508 Answers
  • Posted on Jun 26, 2012
Adam Fjeld
Razor USA Master
Level 3:
Genius:
Answers
1508
Questions
0
Helped
542573
Points
1761
Yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
1 Related Answer
Anonymous
  • 16 Answers
  • Posted on Jun 12, 2012
SOURCE: razor bella problems
Most likely a bad battery. Check out put voltage on all posts. If it's 12 Volts DC or more, then it should be ok, and you'll need to start looking in the wiring such as the speed control switch. If not, your problem is a bad battery cell and you should replace it. NEVER TRY TO SERVICE A BATTERY!!!!!
My scooter has a new battery and turns over but it will not start. I hook up the battery charger and it starts.
[PDF]Owner's Manual - Razor
www.razor.com/.../E3XX_Manual_US_Version1_01-10_US.p...
RazorUSANOTE: Manual illustrations are for demonstration purposes only. Illustrations .... Visit our web site for replacement parts, product support and a list of authorized service centers at ... Your electric scooter may not have a fully charged battery.
tip
How to extend the battery life of Razor Scooter Batteries
You can extend the life of your scooter's battery if you take proper care of it. Most people report trouble in getting more than a year or two out of their razor scooter battery set. This is actually a common problem with vehicle batteries.
  • Keep your battery charged
It is recommended to keep your battery fully charged to avoid the build-up of sulfate-ion inside it. Sulfate-ion accumulates when the battery is in a discharged state for a long time.This is the most common reason of premature depletion of lead acid batteries. This can be easily avoided if the scooter battery is kept in a constantly charged state.
  • Charge you Razor Scooter Battery during the Off-Season
Even if not used Sealed Lead Acid Batteries will self discharge over long periods. This will leave the battery in a not fully charges state which will enable the sulfate-ions to build up inside the internal plates which will slowly deplete the battery's capacity. In order to prevent that, you should charge the razor scooter battery at least once every three months when it is not in service.
  • Use a Battery Tender
Battery Tender chargers are a great way extend the life of your SLA batteries as they are designed to fully charge and maintain a battery at proper storage voltage without the damaging effects caused by trickle chargers.
References:
Battery Maintenance 101 How to Extend Battery Life of Razor Scooter...
BU 804b Sulfation and How to Prevent it
Deltran Battery Tender
1helpful
Where is the reset button at on the razor bella scotter?
there isn't one, but there are fuses by the battery that can be replaced
Razor bella problems
2answers
Razor bella will not go?
one or both of the batteries must be bad, lift the seat up the remove the screws that hold the compartment down and then you should be able to see the two batteries below there, first visually inspect the batteries to see if they look like they are bulging, then test each battery with a multimeter and make sure it is showing at least 12 volts, chances are one or both of the batteries will not show more than 12 volts
Bella scooter light says charged but nothing happens when turn throttle
check the batteries with a multimeteer and make sure they are putting out at least 24 volts
2answers
Razor scooter does not go fast
battery must be bad, there are two 12v batteries wired in series under the seat one or both of them must bad bad so it is not able to supply enough power to the motor. remove the seat cover and visually inspect the batteries and see if one or both of them are bulged
1helpful
3answers
Razor e300 batteries are bulging. Is that normal?
Bulging battery means u have to replace it, the plates started to oxidize and pushes the everything out!
6helpful
3answers
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Top Razor USA Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Razor USA Toy Expert? Answer questions, earn points and help others
