It has a bar on the side attached to the wheels lettered A-G Cutting height. It is setting at F really to high for my grass. I need to lower it a good bit. Please advise. Thanks so much.
SOURCE: MODEL 5521 RS
hi have a 550 horsepower lawnmower and the height adjuster handle has broke where do i get my hands on a new one anybody out that can help please let me know thanks [email protected]
SOURCE: Can a mulching blade work in a non-mulching mower?
True Mulching mowers have a specific deck design to them, but I would say yes to your question.It's been quite a few years, but I have done this little conversion myself - replace regular blade with a mulching blade. Just make sure the mulch blade does fit your mower. Also, use something substantial in terms of strength to close the discharge opening. There can be a good deal of force placed at the opening from flying debris. You'll also want to make the cover removable, so you can mow damp grass without the cover.
SOURCE: Have a murray model 226111X92B 22
go to this website http://www.ereplacementparts.com/murray-226111x92b-2234-lawn-mower-parts-c-17887_17944_19048.html and find the part your looking for. i went to the site and found what you are looking for..good luck
SOURCE: push mower runs, starves, recovers, repeats
Sounds to be the float and needle needs replaced. The float raises the needle to let gas through the carb. If the float isn't working properly the carb starve for gas. If replacing the float, be sure to clean the carb to.
Testimonial: "Thanks, all. "
SOURCE: Craftsman Electric Mulching Mower 37051
I have a craftsman 12 amp. 18" cut side discharge mower. I recently hit a rock and now the blade is loose. how can I tighten it. I have tried tightening the bolt that holds it underneath but can't. any ideas?
