2007 Hyundai Tiburon Logo
Anonymous Posted on Jun 25, 2012
2007 Hyundai Tiburon missing radio
I recently purchased a used 2007 Hyundai Tiburon, unfortunately the radio was not included. What types of radios can I install into this car model? I want it to include radio features along with an aux input place to plug in my ipod. Anyone know what I should buy?? Or radio brands that would fit?
  • Anonymous Jun 25, 2012
    All replacements I've looked at are just CD players that can also connect with iPod, but no radio options included. Please help, I know nothing about cars!! :(
Marvin
Level 3:
Top Expert:
  • Hyundai Master 85,242 Answers
  • Posted on Jun 25, 2012
Marvin
Hyundai Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29052317
Points
266281
Please contact this company for help with a radio that will fill your needs.
www.crutchfield.com
4 Related Answers
Anonymous
  • 8 Answers
  • Posted on Jan 28, 2009
SOURCE: 2003 Hyundai Tiburon GT radio
I had problems with my tiburon gt when I first bought it. Radio would turn on randomly. I looked around though and found rings right above the shifter where he would set his coffee in the morning because his cups wouldn't fit. I bet they would spill now and then and ruined the radio. Simply replacing it should not cause a problem but if you have the radio out get a flashlight and take a look at the wires in the back. I had a friend whos radio would not turn off even with the key out. There was a vacuum line behind his player and it rubbed on some wires in the back and caused him to have a short. Also if you have the factory sub in the back you should still have use of it with a new head unit.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Oct 06, 2009
SOURCE: Im trying to connect my pioneer radio to my
Radio Constant Wire 12V+: Red
Radio Ignition Switched Wire 12V+: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Pink/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Factory Amplifier Turn On Wire: n/a
Left Front Speaker Wire (+): White
Left Front Speaker Wire (-): Brown
Right Front Speaker Wire (+): Black
Right Front Speaker Wire (-): Yellow
Left Rear Speaker Wire (+): Blue
Left Rear Speaker Wire (-): Red
Right Rear Speaker Wire (+): Green
Right Rear Speaker Wire (-): Orange
ees64
Eran Sitnik
  • 12 Answers
  • Posted on Nov 15, 2009
SOURCE: XM Radio in 2008 Hyundai Sonata sounds bad
Same problem here. I repeatedly complained to XM but got no reply. I listen to XM in 2009 Sonata and it was just as bad.
XM is better than AM. Much worse than FM.
Anonymous
  • 62 Answers
  • Posted on Jan 27, 2010
SOURCE: 2003 HYUNDAI TIBURON bcm? Radio, clock, parking
More than likely that is your problem. It should be up under the dash on the drivers side somewhere but i could be wrong. here is a crappy pic of it.f308c8b.gif
2003 Hyundai Tiburon. Can I get a wiring diagram for the radio?
Question edited for clarity.
Question moved to model category.
2003 Hyundai Tiburon Car Radio Wiring Chart - MODIFIEDLIFE
MODIFIEDLIFE https://www.modifiedlife.com > 2003-hyundai-tiburon...
Our 2003 Hyundai Tiburon radio wiring diagram shows you all the radio wire colors and what they do. Table of Contents. 2003 Hyundai Tiburon Radio Wiring Diagram ...
Hyundai Tiburon 2003-06 - Scosche
Scosche https://www.scosche.com > media > guides PDF AMPLIFIER LOCATIONS: VEHICLE MAYBE EQUIPPED WITH FACTORY AMP. LOCATED ON DRIVER SIDE PANEL ON FRONT OF REAR. SPEAKER. W ...
How do you acess the blower motor switch on a '03 Hyundai tiburon
The bezel around the radio and heat/air controls will pull out as one piece using a butter knife and prying around the edge. Also their is a youtube video that shows how to remove the radio which show how to remove this bezel.
3helpful
2005 hyundai tiburon radio not working
check ur fuses look at ur manual will tell you were located evry car is different
2helpful
1helpful
Im trying to connect my pioneer radio to my hyundai tiburon GT 2003, and i need to know what color wires on the radio go to what color wires on the cars wiring harness
Radio does not work on a hyundai tiburon 2000
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
2answers
How to remove stereo cover to put in a new one unit?
I have just purchased a new Pioneer car stero for my 2006 Tiburon. I have just bought this car and we I bought it the face of the radio was missing. How do I remove the old radio from the dash? I cannot find any screws or bolts.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
