Question about Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine
The ekg machine light of filter is flickering and when printing only prints one line out of three appears as if no ink
AT-1
Posted by heidi on
Electro Med Services
  • Schiller Master
  • 6,694 Answers
HI,
Here i added a link which will help you to rectify the problem. Its seems to be the battery of your ECG machine is faulty.
Schiller AT 1 Support
Posted on Mar 16, 2013
5 Related Answers
Anonymous
SOURCE: lower half or EKG would not print properly
You should purchase a printer kit. This is a common problem I have encoutntered on this machine and this machine is identical to the Seca CT6I. I have ordered the printer kit from Seca in the UK, the part number is 9740490024 at a cost of £70. It is a straightforward repair.
Posted on Sep 11, 2009
Anonymous
  • 16 Answers
SOURCE: Won't give print out on Automatic but will give on manual
Turn off the machine & then turn on after 10 seconds. than press ALT 1 1 0 STOP in a sequence. That will solve your problem for printing in AUTOMATIC Mode
Posted on Jul 10, 2009
Anonymous
  • 13 Answers
SOURCE: auto printing problem
Replaced the battery. If this action doesnt resolve the problem contact me.
www.biomedtechpr.com
[email protected]
Posted on Dec 05, 2009
AJIN G
  • 6694 Answers
SOURCE: just ordered a schiller at1 ekg machine, just
hi,
u can make it single channel one by changing its setup. it will print single trace in the same paper. when u select this option it use more paper than the three trace.
ok
Posted on Dec 23, 2010
AJIN G
  • 6694 Answers
SOURCE: The machine cuts off power as it tries to print
hi,
Change the battery, will solve your problem. Its a 12v battery. For replacing the battery you have to open the ecg machine by removing the screws at its bottom.
ok
Posted on Feb 26, 2011
I have a Mac5000. It's currently printing very light. Do I need to change a cartridge? What is best resolution? Is there something I need to adjust on machine?
Sounds like low ink. Try changing the ink cartridge befor yoy get into more stuff. If you check the manual might help.
1helpful
2answers
Just ordered a schiller at1 ekg machine, just realized it is 3 channel, does it have a 1 channel mode where just one tracing will print?
hi,
ok
2helpful
I have been told my printhead is malfunctioning. Can I clean it myself?
You can look in thr user guide or printer help for Troubleshooting and Routine Manteinance.Make sure that the Printer Driver or Paper Type setting in the menu matches the
type of paper you are using. (See Printing in the Software User's Guide on the CDROM.Make sure that your ink cartridges are fresh. The following may cause ink to clog The expiration date written on the cartridge package has passed. (Cartridges
stay usable for up to two years if kept in their original packaging.) The ink cartridge was in your machine over six months.The ink cartridge may not have been stored properly before use.
Try using the recommended types of paper.
CLEANING:
Press Ink.
Press a or b to choose Cleaning.
Press OK.
Press a or b to choose Black, Color
or All.
Press OK.
The machine cleans the print head.
When cleaning is finished, the machine
will go back to standby mode
automatically.
Checking the print quality
If faded or streaked colors and text appear on
your output, some of the nozzles may be
clogged. You can check this by printing the
Print Quality Check Sheet and looking at the
nozzle check pattern.
Press Ink.
Press a or b to choose Test Print.
Press OK.
Print Quality.
Press OK.
Press Color Start.
The machine begins printing the Print
Quality Check Sheet.
Check the quality of the four color blocks
on the sheet.
Is Quality OK?
1.Yes 2.No
Do one of the following:
If all lines are clear and visible, press
1 to choose Yes, and go to step j.
If you can see missing short lines as
shown below, press 2 to choose No.
The LCD asks you if the print quality is
OK for black and three colors.
Black OK?
1.Yes 2.No
Press 1 (Yes) or 2 (No).
The LCD asks you if you want to start
cleaning.
Start Cleaning?
1.Yes 2.No
Press 1 (Yes).
The machine starts cleaning the print
head.
After cleaning is finished, press Color
Start.
The machine starts printing the Print
Quality Check Sheet again and then
return to step e.
Press Stop/Exit.
If you repeat this procedure at least five
times and the print quality is still poor,
replace the ink cartridge for the clogged
color.
After replacing the ink cartridge, check
the print quality. If the problem still
exists, repeat the cleaning and test print
procedures at least five times for the
new ink cartridge. If ink is still missing,
call Brother Customer Service
2answers
Cant read EKG Strip
I suggest opening unit and cleaning all mechanics first. For more suggestions I need Mgfr. & model number.
Feb 11, 2010 • Medical
Lower half or EKG would not print properly
2answers
Schiller machine is not printing
If the unit print lightly or not printing anything at all?
The most common causes for not printing ECGs is one of those:
1- Too little heat on the stylus
2- Insufficient stylus pressure on the paper
Solutions:
1- Using an insulated probe, such as a screwdriver, gently press the stylus onto the paper.
2- If a dark line appears on the paper, the problem is too little pressure, but if no dark line appears, the problem is not enough heat.
2answers
I ahve a schiller welch allen EKG machine, and now it only prints
If it stops printing completely in the middle of doing the print, it is because the battery is bad and needs to be replaced.
If it only prints some of the leads but it does print the full report it is because you have the leads mixed up (Wrong spot on the patient) or the leads are mislabeled or some of the clips or electrodes are bad.
I can fix these. Let me know if you need help.
1helpful
2answers
Schiller AT-1 ecg not printing.
Turn on machine, wait a few seconds then press ALT-0-1-1
You will get a print out showing all the settings
2answers
Hello LV792727, Disconnect the AC & battery power and proceed with caution. Open the case to aquire access to the thermal print head. Clean the print head with a white eraser, the type used for cleaning ink prints not the #2 pencile eraser. Test the printing function. If necessariy use a Q-Tip with a light touch of Aceatone to whip the print head. The next step is replacing the printing element. Please inform me of the results. Good luck.
Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine Logo
Top Schiller Medical Experts
Mark Ultra
Tom Chichester
Are you a Schiller Medical Expert? Answer questions, earn points and help others
