Question about Leviton Electrical Supplies
HOW TO WIRE A COMBINATION TWO SWITCH - Leviton Electrical Supplies
Posted by sawelch53 on
Gene Haynes
  • Leviton Master
  • 5,391 Answers
Copy following link to see illustrations of switch wiring, including combination switch, and 3-way switches, double switches etc
http://waterheatertimer.org/How-to-wire-switches.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jun 30, 2012
Trying to wire switch and plug combination where the switch will turn off the plug
Black wire to brass connection on switch. White wire to silver connector on receptacle. Add a wire from the silver side of switch to the brass side of the receptacle. When switch is on current flows through to it to receptacle then out white when something is connected to the receptacle.
Nov 19, 2013 | Cooper Wiring Devices Combination Switch &...
Replacing a switch outlet combination with a switch GFCI outlet combination and there is only one cable in the box (14/3)
If it worked before, it should be a wire to wire replacement. You are replacing a regular switch/outlet with another switch/outlet which just happens to be a GFI outlet.
Wire the old switch wires to the new switch and the old outlet wires to the new outlet.
Cut the breaker/s off first !!
Sep 25, 2017 | Cooper Industries Electrical Supplies
Highbeam switch
  1. If equipped, disable the SIR system. Disconnect the negative battery cable.
  2. Remove the upper steering column cover.
  3. Remove the lower steering column cover screws and lower the steering column cover.
  4. Remove the 2 switch mounting screws and remove the switch.
  5. Detach all wire connectors from the combination switch. Push locking tabs to remove the wires.
To install:
  1. Attach all wire connectors to the combination switch.
  2. Install the combination switch to the column with the 2 attaching screws.
  3. Install the lower steering column cover screws and lower steering column cover.
  4. Install the upper steering column cover and attaching screws.
  5. Connect the negative battery cable.
  6. Enable the SIR system, if equipped.
Dec 04, 2011 | 1999 Pontiac Sunfire
How to wire a combination switch & receptical to plug in a garbage disposal?
Bring a cable with 3 wires (hot, neutral, and ground) into the combination switch and receptical. The hot wire connects to the LINE portion to power on the receptical. Use another cable with 3 wires to connect the LOAD portion on the switch to power on the disposal. The black wire is the HOT wire that should be switched. The white wire is the NEUTRAL that can be tied together, and the green wire is the GROUND that can also be tied together.
Aug 14, 2011 | Hardware & Accessories
I need to wire a combination GFCI/switch using incoming 4 wire (red, white, black, bare) and outgoing 3 wire (red, white, bare) replacing an existing switch. How do I wire this properly??
Can you tell me where the outgoing wires are going to. Bare wire is ground goes in green color screw, white wire is neutral and goes in silver color screw, black wire is hot or live and goes in gold color screw. It is difficult to help you with little information. how do you know what is incoming and outgoing.
Mar 06, 2010 | Leviton 8299 Combination Switch / Smart...
Wiring a leviton 5625-W switch receptacle combination
You cannot replace the switch with a switch/receptacle combo because there is no neutral wire. The black and white that you see are both used as hot wires. One is the Line and the other is the Load.
You have to install another 2 wire cable or replace the existing with a 3-wire cable. A 3-wire cable has a black, red, and white, plus the bare ground wire
Sep 02, 2009 | Leviton Decora Combination Switch - 5625-I...
Leviton 8299 Combination Switch / Smart lock GFCI Outlet Leviton-
power coming in from the breaker box: black wire will go to line-hot screw, and the white wire will go to the line-white screw. the switch wires coming out of the back of the gfci- 1 will go to the load-hot screw & the other black wire will wire nut to the black wire going to the light. the white wire going to the light must go to the load-white screw.
Apr 12, 2009 | Leviton 8299 Combination Switch / Smart...
Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
Mar 03, 2009 | Pass & Seymour / Legrand 1595-2SWT...
Electrical Supplies Logo
911 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
john h
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
