Setup error or incompatible EEPROM
Control Microprocessor Version
Ask for EEPROM Spare Part indicating Microprocessor version
Reflash EEPROM
Check electronic controller
Remove the lower plastic panel at the front of washer.
The filter is located at the bottom front right.
Unscrew anti-clockwise to remove and clean.
Have some cloths handy as thetre will be some water that will come out.
Th e fault code indicates a problem with the dryer fan or the thermistor as being the cause of the problem. Check for broken wire.
These are located in the top of the washer, access is gained by removing the top cover.
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
