Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem. If your laptop as a built-in wireless card you can to the Internet via the wireless router. If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Start by checking for "link" between the modem and wireless router. This is usually a tiny light built into the network port itself on each piece of network equipment. It should be solidly on if the link is good. If it isn't on, check that you have the network cables plugged in good and that the cables or connectors are not broken or damaged. If you have another network cable, try it instead of the one you were using.
If these steps don't help, you can try fully resetting your wireless router to factory defaults, then reconfiguring it again. Consult the manual for your brand and model of wireless router for this. It may also have additional troubleshooting steps.
There is a chance your wireless router has simply gone bad. I've seen new Belkin wireless routers for as little as $29, so you may want to go that route, rather than spending too much time trying to troubleshoot the one you have.
To be able to set up wireless printer configuration, there are three basic items that you need to have. They are a high-speed broadband Internet connection (with modem), a high speed wireless router and wireless network adaptors. These three items will be used in setting up the wireless printer. Assuming that there is already an existing network in the home or office space, then all that is needed to do to make the printer available in the network through the operating system's networking wizard. If not, then the network must first be established, only then the printer will be made available through that network.
There will be something in there, whether it is toner/ink over a sensor, a paperclip/staple, or a tiny scrap of paper. The trick with this one is patience, methodically strip it down as far as you can, checking as you go for stuck material, and once you have gone as far as you can put it back together nice and slowly, looking for broken connections and loose bits, then try it again.
If there is nothing in there then the printer has something broken and needs looking at by a technician, in this case you should turn to your warrenty.
Depending on the model etc of your laptop, some have built in wireless adapters others don't so you need to buy a wireless adapter card so that you are able to connect to the internet.
Also you will need a network which has wireless built in if at home for you to connect to the internet, through the wireless adapter on your laptop.
Hope this helps, let me know if you need more information.
Once connected to the ethernet cable you might have to press the tiny reset button on the back of either your gateway,router,modem of whichever service you have(Cable,DSL)
Hi from France,
I am now repairing my printer (Photosmart 8050) with the same problem. It is due to the welds of the USB pins of the socket on the printed board. It is thus necessary to open the printer by means of a screwdriver Torx. You need a little soldering iron in order to weld the four pins of the USB socket, and then I recommand to strengthen the connections and the socket by means of hot glue.
