Samsung NV20 Digital Camera Logo
Question about Samsung NV20 Digital Camera
Video sound problem
I have bought a Samsung NV20 digital camera recently. The picture quality and video picture quality is great. However when I film music videos at gigs it cannot seem to cope with the volume of the music. It sounds all distorted. I have gone into the settings menu and turned the input volume down to low but this has not made any difference. Is there anyway you can help? Many thanks
Posted by thompsonclan on
  • Anonymous Jan 13, 2009
    i get the same problem with the nv20, i dont think it has the functions to lower the volume of the built in mic.
    But will be interested what people will come up with.
richie46
    Top Expert:
  • Samsung Master
  • 12,962 Answers
Camera not working properly. New - I would return and exchange
Posted on Aug 25, 2017
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: hdtv-dlp has no sound or picture
This sounds like an o-so familar problem. It sounds like the Switching IC or the MICOM has failed
Posted on Nov 10, 2006
Anonymous
SOURCE: Uploading videos with sound
Find out wich audio codec the camera uses to record audio and install it on your computer.
Posted on Aug 29, 2007
Anonymous
SOURCE: samsung s730 digital camera no sound on video clips
I contacted Samsung today regarding the same problem. Their recommended solution was to download VLC Media Player for Windows from http://www.videolan.org/My which I did.
My default security settings on Vista did not at all like this site. I had to navigate through about 10 different warning messages. However, it did install easily, seems safe thus far and it does playback the videos with sound.
Posted on Dec 29, 2007
Anonymous
  • 39 Answers
When downloading video files to PC, the Software CD needs to be installed first to the PC because a video file is requiring some CODES that are contained in the Software.
But the software to be installed needs to be compatible with your PC's operating system like Windows XP, 98, etc...
Usually, the OS wherein the disc is compatible with is written on the disc itself.
For MAC and Windows Vista users, the disc may not be compatible with your PC, but you could try using any applications that you may have with your OS to play the videos.
If it still does not work, you may download freely a movie player that will work for all OS through videolan.org
Posted on Jan 11, 2008
Anonymous
  • 75 Answers
SOURCE: no sound on videos while zooming in/out
There is an option in the Sound option of your camera.
You need to turn on the AF option.
Posted on Jan 14, 2008
Samsung nv20
Sensor and mother board are dead.
Dec 18, 2017 • Cameras
My memory card is not being read in my samsung nv20 camera.. after taking 6 pictures the camera tells me that memory is full, i have tried taking the card out and back in again, but no luck, the card is a...
The NV20 is a 12MP camera, and can fill up a 1GB card fast, especially if you accidentally take a video (thinking it was a photo). Have you checked to make sure that all your photos are actually "photos" (i.e. not videos)? Other troubleshooting steps for memory card problems may be found here.
I exposed my nv20 to smoke/steam. and since then my screen became blurred. but when i view pictures on the screen, it is perfectly clear. i think the lense must be faulty. please help.
There may be some moisture inside the camera, take the batteries out and put it in the airing cupboard for a couple days, See if it improves.
14helpful
How do you turn the sound on for recording video with sound.
I know this sounds stupid, but click the up arrow to go into the setting mode and scroll down to the "Optical Zoom" setting and select "OFF". This will allow sound recording. I think Casio sets the camera up this way to avoid recording the sound of the optical zoom motor noise.
Hope this helps...
Have downloaded video from my camcorder onto my laptop but when I play them the sound runs ok while the picture runs slow ( out of sync)
Ok...your title says camera but your post says camcorder. If it is a digital camera then nothing is wrong with you camera or laptop. Usually the video taken on a digital camera is of poor quality and vice versus with a camcorder the pictures are of poor quality. They make it seem like you can do both with exception to newer camcorder which has a 6 to 8 mp camera built in.
Jazz DV179 - Poor video Quality when filming at night.
  • If you can manually change the sensitivity ie iso you will get better images in low light. My digital camera on auto is not good in low light but I do the above and get satisfactory images.good luck...jw
Digital camera nv20
charging the NV20 is simple, just plugin the cable to the power supply and it will charge. Inorder to charge the camera you must leave the battery inside the camera and when it's done charging you will see the lit up arrow on the end of the cable turn from red to green.
1helpful
2answers
Picture quality has become terrible
Ed, The shutter on your camera has become stuck open. This causes the lines across your pictures. If you take the camera outside or shoot in bright lighting conditions the pictures will come out over exposed. The fix for this problem requires complete disassembly of the camera to access the shutter assembly inside the lens. It is a fairly common issue due to the fact that the shutter is such a delicate component. Check with your manufacturer for warranty support or recalls. If they are unable to help you for free, there are repair providers which you can find online who will repair your camera for a reasonable rate. David Millier Advance Camera Repair
4answers
Poor Video Quality
My capture software defaults to capture specs of 720x480x32 at 29.97 frames per second. It previews video at 360x240x32 at 29.97 fps. What resolution is your capture operating at? How about the camera?
T7 video
Hello The zoom does not work on the T7 while you video, you have to zoom first and then start to video, then it is fixed at that zoom setting. Other than that, the video is pretty good, I have taken video clips up to about 5mins (but in theory you can go up to the limit of the mem card and battery - battery from full is about 40 mins from the top of my head and my 512mb mem card could do about 30 mins on best quality) The sound is good, and the picture is pretty good, but obviously there is no 'flash' function, so you are looking at daytime or well lit video only. One thing is that you do need a steady hand, because the unit is so small (a great benefit most of the time) you do get a fair amount of camera shake if you do not have a very steady hand... usually the morning after the night before for me! :o) I have been pretty happy with it a a fun video accessory, but if you want the camera for that as a main use, I would look around. Sasson
Top Samsung Cameras Experts
David Shaub
Paul Bade
Are you a Samsung Camera Expert? Answer questions, earn points and help others
