SOURCE: Where is the Serial Number on my HP Scanjet 3970 Flatbed Scanner?
The 10 character serial number and the product number are located (on my 3970) on a sticker on the inside of the cover.
You can verify that you have the correct numbers if you enter them at
http://h20000.www2.hp.com/bizsupport/TechSupport/WarrantyLookup.jsp?lang=en&cc=us&prodSeriesId=298547&prodTypeId=15179
That will tell you if they are the wrong numbers as well as the warranty status of your scanner.
Thanks,
SOURCE: I can't find the Serial Number on my HP Scanjet 3970 Flatbed Scan
I see The Serial number the scanner needs is the registration number and that is usually found in the paper work you have or written on the cover of the CD I would leave the two versions on there because one should have updated the other one (see what happens when you put the number in)
SOURCE: My printer HP scanjet installation hardware is broken
If your operating system is Vista use the following link to download the driver
HP Basic Feature Driver
If your operating system is Windows XP use the following link to download the driver
CD - HP ScanJet 2300/3500/4500/5500 Series Photo and Imaging Software
I hope this will solve your issue.
Goodluck
If my solution proves useful please accept it.
Regards
Arjun
SOURCE: I need a HP Scanjet G2710 Operating Manual
http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=3423844&targetPage=http%3A%2F%2Fbizsupport2.austin.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fc01825496%2Fc01825496.pdf
SOURCE: i can"t scan to PDF
Hi
Use the Scan to PDF software to direct convert your scan page to PDF, download the software to click hear
and simple to install to this software, after installing you get the shortcut in your desktop double click that one and open your scaner is automatic install there put the document in scanner and click scan after scanning click save to PDF and give the save file name and save.
Nice one may it is resolve you problem.
Cheer
