Question about Creative Labs Zen Digital Media Player
Zen will not turn on for me
The mp3 player is only 3 days old. i had charged the battery until the battery symbol turned fully green and had to quickly disconnect to leave. only a few minutes later i tried to turn it on to listen to but it refused to turn on for me. no matter how hard i try, it wont turn on. does anyone have a answer to this? if you do, please answer quickly because i dont want to have to tell my parents about my ruining it only shortly after getting it, they will be furious...HURRY!
  • Anonymous Dec 05, 2008
    Same problem I just had...is there a way your supposed to disconnect the Zen from the computer??? because I couldn't find a way other then to just pull the cord out....bed idea, it won't turn on anymore. The blue light is still on though? Help!
4 Suggested Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Creative Zen Touch Controls
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
Posted on Jan 28, 2008
Anonymous
SOURCE: CREATIVE ZEN V-PLUS. COULD NOT TURN ON AND IS NOT CHARGING
my vision m wont charge. and i just tried to click that button and pluged it back in and its still not working :''''''[
Posted on Sep 19, 2008
Anonymous
SOURCE: Zen V not charging, battery all out
Try resetting the device and charging it again. You may have to charge it for a few hours though.
Posted on Apr 22, 2009
Anonymous
SOURCE: creative zen mp3 player won't turn on. already tried resetting
Mine did exactly the same and i thought it was dead, but when u are reseting it keep it plugged into the computer while reseting it and it should turn on. It worked for mines anyway.
Posted on Jul 15, 2009
How to the Zen Mozaic player is fully charged
once your mp3 player gets fully charged you can see in the screen of your mp3 player showing "full" near the battery symbol.
Dec 08, 2009 | Beond Creative Technology Zen Mozaic MP3...
My zen moziac 300 won't turn on
Support for EZ300:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=231&subCatName=MIDI+Keyboards&prodID=18430&prodName=ZEN+Mozaic+EZ300
1. Have the player charged.
2. Push the resetbutton on the left side with a paperclip.
3. When this not solves the problem perform the "mp3 recovery tool" [Note: first back up the data content of the player]:
http://www.creative.com/mp3playerrecoverytool/
Aug 21, 2009 | Creative Technology ZEN Mozaic EZ300 MP3...
Apr 14, 2009 | Creative Labs ZEN V Plus MP3 Player
Freezing
That happens to mine, too. What you do is stick a pin through the little reset hole on the left side (under the switch you hold down to turn it on). That should reset the player. If that doesn't work wait until the battery runs out and then charge it.
Aug 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen m wont turn on
Well, it needs to charge via USB on your computer, so plug in your zen into the computer with the creative usb cord, and let it recharge. It may not necessarily turn on if it's really out of battery, but you can tell its charging when the switch you use to turn on and off, and hold, the light is blinking. After sometime, your Zen screen on the upper righthand corner should show a little battery and be blinking green what stage it's at in its charging. When its done charging the battery icon with be fully green, not blinking, and have a little plug icon inside of the battery icon to indicate that it is fully charged--takes a couple of hours to charge.
If that does not work, check your USB cord to make sure it's not damaged in any way. If it is, you may need to purchase a new one for better connection. And if that doesn't work, then you might need to replace the battery altogether, which I'm sure, if you are still in your manufactuer's warranty, they can do for you. After it is replaced, your zen should be good as new and ready to operate.
Hope this helps. Good luck!
Jul 17, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Zen Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
