Honda GCV 160 mower has two blade controls - can't get the mower to cut grass
You will need to know your serial number. They are free to download, but if you want to order a paper copy, you have to pay for it. Hope this helps and please don't forget to rate!
http://engines.honda.com/parts-and-support/owners-manuals/GCV160
SOURCE: Need to know how to change the oil in my Honda
take out the drain plug under the lawn mower drain it put the plug back fill it with oil then you done
SOURCE: Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The
motor isn't on full throttle.
2. The blade is upside down.
3. The grass is
too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
SOURCE: BLack and decker electric lawn mower blaDE IS loose and not turn
If it's like mine (MM 875), it has a plastic "clutch" that has little edges on it that broke off when I was chopping sticks with the mower ;-) Went to the local B&D place and got a new one for less than $3.
But now I'm worrying about the nut holding the blade on -- if I try to get it good and tight, the plastic "clutch" spins around off-kilter... Funny how I never even looked at the blade after I bought the mower used, but never worried about the blade being loose and flying off.
SOURCE: I have a Honda GCV 160 LAWNMOWER IT WILL ONLY RUN
BEFORE you go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, runs for 10-30 seconds, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers ---- http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
SOURCE: lawn mower husqvarna problem
I have an XT721F self-propelled, auto choke Husqvarna mower. The first time I used it this season it ran for a short time and then just quit on me. I have since emptied out all of the gas and have replaced it with high octane 91, and have also added Seafoam to clean out any other issues. I mowed two weeks ago with no problems and went to mow again today and only made it through 2/3 of my back yard and the mower stalled out on me again. What's going on?
