Question about Sony BRAVIA KDL-32S2010 32 in. LCD Television
Vertical shadows every 3" on sony bravia 32 about 1/4" wide
I have just brought a 32 inch Sony Bravia off of eBay, it has faint vertical shadows all the way across the screen at 3 inch intervals, they are fairly thin but very noticeable on solid colour backgrounds - any suggestions on how I can fix this? Also will they get worse if I leave it? Thanks
    New Friend:
  • 39 Answers
Image burn from leaving it on.. Its the vertical colors we get when we disconnect everything.. Its stand by screen.. It won't get worse.. But u either have to replace it.. Or live with it..
Posted on Feb 06, 2018
6ya staff
SOURCE:
Anonymous
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
Anonymous
SOURCE: Sony Bravia 32 inch HD LCD tv has vertical lines
We had a similar issue although our Sony Bravia was 21 months old. We were told by an engineer that the panel has failed and that the cost of replacing it would be about 900. We were also told that this is a very common fault and that the "normal" failure time was within 18mths to 3 years. If you registered your TV purchase with Sony, it might be worth contacting them with the serial number to see if you could get it repaired under guarantee. We have now bought a TV with a 5 year guarantee!!! (not a Sony!!!!)
Posted on May 26, 2009
Anonymous
  • 131 Answers
SOURCE: My Sony bravia 40
other than a software upgrade. it probably a graphics chip malfunction and will need replacement.
These can be replaced but costly. Does it do the same if you use screen as a pc monitor?
AndystUK
Posted on Aug 31, 2009
Anonymous
  • 210 Answers
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Posted on Oct 01, 2009
Anonymous
  • 50 Answers
SOURCE: I have a 46' Sony Bravia that has a thin bright
sounds like a video or mains fault.
Posted on Oct 13, 2009
White spots on sony bravia 32" S series
what is the cause for the televisions screen to get white spots that spread
Aug 05, 2013 | Sony BRAVIA Televison & Video
Sony KDL40EX400 has (2) 2 inch wide vertical color bars about 4 inches from the left side of the screen. Purchased July 2010
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 22, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-40w4100 vertical line issue
Ok after over a year i figured out it was the tcon board. Good luck getting finding one. The first one i ordered from shopjimmy was faulty, didn't realize until after the warranty so i ate the cost of it (honestly i thought that it was good and there was another thing wrong with the tv) so i said wtf and bought one last week from ebay. Bam! it works great!!!
Jan 10, 2012 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Tv picture is pink with vertical lines sony bravia 32 inch XBR
it sounds like a bad t-con board. this board my not be sold without geting the whole screen. the t-con borad is at the top of the screen and connects to your main board
Apr 15, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Dec 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia 32 inch HD LCD tv has vertical lines going down 2/3 of screen. No idea what problem is. Tv is less than a year old, but I have lost the receipt. Anyone had this problem or know what may be...
May 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Vertical lines in screen
Are the Lines Symetrical in distance and space? Makes a diferernce..
Jan 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA KDL-32S2010 32 in. LCD Television Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
