Question about Dual Electronics Mini Dual Mode USB VGA 300K 640x480 16MB Keychain Digital PC Web/Video Camera Digital Camera
How can i get my images off of my camera if i don't have a cd
I cannot get my images
Posted by Susann on
Al Kemist
    New Friend:
  • 22 Answers
You don't need a CD -- You need a computer and a burner
Attach your camera to a computer via a download cable and save them to your hard drive until such a time that you have a CD/DVD burner and a CD or DVD disk then transfer them all to a CD/DVD
Posted on Jun 24, 2012
Can't transfer images from G12 to computer
Does the camera have internal storage or does it require a memory card? I don't see any specifications for internal storage. If you are using a memory card then try taking the card out and inserting into the appropriate memory card slot on the computer. </br>
It seems that the camera uses standard USB to connect to the computer, however, the documentation implies that you need to install the accompanying software from the cd to view and transfer your pictures and movies using this method.
2helpful
I was given Fuji Film FinePixF50fd camera with all the connectors for computer, however I have no CD with the software so I can't upload my images onto the computer at the moment. Is there a way o
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what said first, you can use any photo cataloging program such as Picasa.
I have made a disk image, with file extension .wmf, but don't know how to open it and get all the disk data back ??
wrong file extension. if you made a image of the OS it should have been a .iso this is burnable and easy to open with winrar or a dvd burner program for image burning.
The ISO file type is primarily associated with 'ISO-9660 CD Disc Image'. A literal dump of the data on the CD, byte-for-byte. The data is stored in the ISO-9660 format. IsoBuster can interpret these files directly.
The .wmf file type is primarily associated with 'Windows Metafile' by Microsoft Corporation. Microsoft graphic format. Xara X is a good program to edit this file type if you don't have Microsoft tools. There are several versions of a Metafile; each having a different header structure.
Need drivers for ge x500 camera
On newer operating system I think this one gets recognized but if it doesn't for you you may have to run the setup cd you should have got with the camera.
That will install any files or drivers needed as well as the image editing software.
The main page for it is here:
http://www.general-imaging.com/us/Digital-Camera.aspx?id=1962
And the support page is here (where all the file downloads are):
http://www.general-imaging.com/us/supportDetail.aspx?id=1962
Just go there and click on what you want along the left side of the screen. Make sure it is showing the x500.
If my links won't work then you need to go to
Click on our cameras then the picture of your camera. For support stuff just click on the support link and chose the picture again. That will get you to the same pages as the first links. The software should detect when the camera is plugged into the usb. I do have one canon that refuses the play nice and won't do this so I just use a card reader to transfer the pictures right off of the cards.On the same page is contact information for support don't be afraid to call them and ask them anything.
1helpful
I have a DSC-T70. If I were to take a picture this way: http://i37.photobucket.com/albums/e96/Gamfrk924/landscape1.jpg then when I view my image, the picture would be rotated like this...
1. Go to Menu items
As seen in the picture above, there is a setting there to Rotate your still images.
3. Rotate your images and Save.
Have Fun!
4helpful
Does the dscw310 have date stamp capibility?
Common, Sony cameras don't add date stamp at the time you shot for conveniently edit after shotting. If you want to add time for your picture you can install it using the Sony applications software in the CD which comes with your camera, and there are faction of add date stamp, you can also use other image processing software to manually add text and date,more flexible.
1helpful
2answers
Impossible to connect camera with PC. no driver in the PC for camera powershot A510. What's the matter?
Just figured this one out. Man, they don't make it easy. I'm borrowing my roommate's PowerShot A510 and since it has a USB port going out, I'd assume I could simply connect the camera to my PC and access my images directly. Almost every other camera I've seen will register itself to Windows as a straight USB connection (prompting the Windows screen asking how you want to open the connection - 'open folder' etc). This one just sits dead quiet about things :)
If you've just bought this camera at a garage sale or are borrowing it or for whatever other reason do not have the "bundled" software and driver CD or have the camera's serial number, do not bother trying to find windows drivers or try to obtain any software from Canon. You won't get very far.
FINALLY found the solution in the User's Manual (which was free thank God). You can download the manual here: http://usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a510#BrochuresAndManuals
(Select your operating system and download the "PowerShot A520/A510 Camera User Guide". File name is PSA520510CUG-EN.pdf)
In the User Guide, page 107 (I'll paraphrase):
1. Put camera in Play mode (the switch on the back (green arrow in green box)
2. Press Menu button (center one of the three along the bottom of the view screen)
3. In the 1st menu option (Play Menu, again green arrow in box highlighted), use the wheel button to scroll down to highlight "Transfer Order". Press Set (center of wheel).
4. You should now see "Transfer Order (DPOF) at the top of the screen and "Qty. of images 0".
5. Below "Qty of images 0" you'll see "Order", "Mark All", and "Reset". Order lets you select individual images; Mark All marks all current images for transfer; and Reset is reset. Press Set to choose.
Note: pressing the Menu button while selecting images brings you back to this main screen. If you are already at this main screen and you aren't ready to do your transfer yet, DON'T press the Menu button from this screen as it will initiate the transfer to your computer. Not a horrible thing, but might cause a mini freak-out.
7. Once you're selected the images you want to transfer, from the main Transfer Order window (now showing "Qty. of images" with a count of the images you selected), press the Menu button.
8. You'll see a white progress bar at the bottom of the screen. Don't worry! it's not deleting files or something bad.. (my first thoughts :) ..
9. Go to your PC and Voila! the Windows AutoPlay screen is now active!
10. Proceed with normal Windows USB operations (transferring at least, I didn't try any deletion).
I hope this helps somebody else out there who spent the last 3 hours trying to dig through internet hell to get this to work.
Atm, this is as much as I know so I probably don't have any good answers for any questions. Sorry :))
But, hope this helped at least!
Cannot locate CD that came with Canon PowerShot S30
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Dual Electronics Mini Dual Mode USB VGA 300K 640x480 16MB Keychain Digital PC Web/Video Camera Digital Camera Logo
Top Dual Electronics Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Dual Electronics Camera Expert? Answer questions, earn points and help others
