Chain is loose on the dynacraft 20 inch girls bike. Has come off a couple of times. Is there a way to tighten the chain
SOURCE: mongoose tactic mountain bike / loose crank on
The crank has to be removed to tighten the nut that holds the gear on. I assume that is your problem is with the chain gear on the sproket that is loose
Testimonial: "I need a special tool to remove crank /nothing Ive ever seen"
SOURCE: Dynacraft Slumber Party 20 inch girls bike
Make sure you follow the directions carefully. You might try leaving the flat washers out or substituting thinner ones. Worse case you will have to go to a bicycle shop and purchase a longer axle. Make sure you keep careful track of how you disassembled it and take pictures or make drawings. The hardest part with replacing an axle is getting the proper resistance on both sides so the bearings don't bind. Check www.sheldonbrown.com for some helpful articles.
