Question about Toshiba CT-864 Remote Control
Is this a universal remote or only for Toshiba devices? I have a used Zenith tv.
I got a Zenith Model #: IQB27FW and found this Toshiba remote. The power button does not work on the tv, but I was told the tv will work with a remote. What is the code to have these two products work together?
    Top Expert:
  • Toshiba Master
  • 76,171 Answers
These are the setup codes for Toshiba TV. Brand name of the remote control isn't matter. If the remote control you try to synchronisze have any of the above said code, it can be used to setup with your TV. If not, it is not possible. If you wish to get more details about codes and setup proceedings, visit this site [Electro-help]. type in "electronicshelponline.blogspot" into the search box of your browser and click search. Pull up older post there. It is a blogspot site, in English language.
Posted on Jun 25, 2012
6ya staff
SOURCE:
dvinnedge
Dale Vinnedge
  • 35 Answers
SOURCE: Need product codes to program Universal Remote
I have the following toshiba codes
10154, 11256, 10156, 10093, 11265, 11060, 11356, 11369, 11524, 11635, 11656, 11704, 11918, 11935, 11936, 11045, 12006, 11343, 11325, 11306, 11164, 11156, 10845, 10832, 10822, 10650, 10149, 10036, 10070
Posted on Nov 29, 2008
tvtech15
  • 18 Answers
SOURCE: I can't find a manual for the toshiba ct-90251
check this out : http://remotes.com/remotes/documents/Toshiba/CT-90251.pdf
I found it on this website : http://remotes.com/store/codes_original.html
hope this info helps you.
Posted on Sep 21, 2009
tvtech15
  • 18 Answers
SOURCE: universal remotes work at first for toshiba tv
I'm not sure , did you try checking to see if the batteries are good
gopakumarg43
  • 76171 Answers
SOURCE: I need the code to a universal remote brand auvio
Check these codes.
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Posted on Apr 30, 2012
chalio1214
chalio1214
SOURCE: need programing codes to run my cble, vcr, and dvd
i need the code for my toshiba ct90159
Posted on Jun 02, 2012
Zenith remote will not work tv, need code
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
May 16, 2009 | Zenith DBZN-311 Remote Control
Program my zenith converter box to my tv
while holding down the tvs power button push the channel up or down slowly. this will turn your tv off when your code is found. when it is found and your tv goes off release the power button. now your remote will work with your tv...........
Dec 28, 2008 | Zenith C27A24T 27" TV
Zenith dvd/vcr mod #6711R1N211C. Need to prog the volume button.
In my manual, to control a sony TV.. the code is number 8 or number 9.
You will hold down TV POWER, hit 8 then release TV POWER.
If that doesn't work, try number 9. Once the batteries are removed, it resets the code, so write it down. It will also over ride your old codes once you input the new one.
Note: Depending on your TV, some or all buttons may not function on the TV, even after entering the correct manufacturer code.
I looked for the section on Stereo, but all I found was the above.
Hope this helps.
Nov 22, 2008 | Zenith XBR411 DVD Recorder/VCR
Optical eye
LOL, optical eye? OK, that’s the problem, there is no such part. However, you did not say if any other buttons were working on your remote, ie ch up and down, input, power on and off, ect. If so, it will not be your remote. If you the volume is not working, check you menu setup, under the audio setup.
If no remote functions are work, you can try the inferred Receiver. Its only about 20.00 to replace and can be found at most part stores. Cheaper if you change only the IR block itself.
TV tech
Jul 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
CONTROL CODES FOR HITACHI DV-RMPF2
I found the user manual online - directions are:
Turn TV off
Hold RED TV Power button down
and at same time per manufacture of TV...
Hitachi - 1
Sony - 2
RCA - 3
Sanyo - 4
Zenith - 5
Panasonic1 - 6
Panasonic2 - 7
Sharp1 - 8
Sharp2 - 9
Toshiba - 0
JVC - Clear
Mitubishi - +10
Magnavox - SUBTITLE
Funai - AUDIO
Goldstare - DISPLAY
voyageurs60
Jul 10, 2008 | Televison & Video
ZENITH D52WLCD
I just found the solution on another model of Zenith TV. Hold the enter button down on the TV and the MUTE button on the remote. In approx. 5-7 seconds a screen will pop up asking if you want to reset the lamp timer. Hit the bullseye button in the middle of the arrows and it will reset. Worked perfectly.
Apr 15, 2008 | Zenith D52WLCD 52" Rear Projection...
Toshiba tv code for Zenith remote
Check the manual for your Zenith; many of the Zeniths (and many others) have a 'scan' mode you can call up, in which you can repeatedly press one key (^ for example), then the Power Button. That will force the remote to set every code it has available, step by step.
If you no longer have the manual, you may find it here or several other sites that offer these.
Apr 09, 2008 | Zenith MBR3447 Remote Control
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Zenith ZN-501S remote control codes and instructions
From the ZN5015 code manual for Quasar TV 007 107 416 608 618 718 807 901
Apr 15, 2007 | Zenith ZN-501S Remote Control
Toshiba CT-864 Remote Control Logo
88 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
