I can't get my clock set on my aiwa cx-nma545 & I no longer have a remote.
The original remote is needed to get into the main menu, try www.aiwa.com contact customer support, also! go to www.ebay.com type make and model of unit and go through the list you might get lucky.
If the clock is not showing on the screen it would suggest something else is wrong, normally it would set back to 12:00 oclock, you can try unplugging the unit, press power and hold for 60 seconds this may reset the processor and return clock. On some units press menu and use the volume up and down to change time, each section will flash when menu is pressed to adjust clock.
We were able to set it before by accident. It's just that when the power went out, the clock no longer shows on the screen and it would be nice to be able to reset it.
