Question about MSI P4M900M-L (7255-060(P4M900M-L)) Motherboard
Sound has died
Working, Crackled and Sound Died. Repair help needed.
  • Dennis Leefarr
    Dennis Leefarr Jun 25, 2012
    I have purchased a USB Sound Card Dongle as there are no PC1 slots. will let you know if it works when it arrives. Dennis
  • joecoolvette
    joecoolvette Jun 26, 2012
    Excellent! Would appreciate hearing back from you. Should have stated using a USB sound dongle. Still old school in thinking, I guess.
    (No OPEN PCI slots available? Understandable. Filled in with add-on adapter cards, huh?http://en.wikipedia.org/wiki/PCI_local_b... )
  • MSI Master
  • 5,660 Answers
Http://computerpartdiscounters.com/microstar-p4m900m2-ms-7255-motherboard-version-2-1-socket-775.html
Dennis, quit fooling around with that OnBoard audio on that mobo.
Just install an economical sound card.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1747731&CatId=2771
This baby will S-M-O-K-E the onboard audio you have now. (Or did)
Just install in any available PCI (White) slot.
Regards,
joecoolvette
Posted on Jun 25, 2012
My engine died after replacing water pump there was a flapping sound then it died and would not start.
Unfortunately, it sounds like the timing chain has broken,(the "flapping sound"), did you check for spark or use a timing light. If not I would start there. Cost nothing and will rule out a costly repair. Or will confirm my hunch
May 05, 2014 | 1992 Buick Century
Bush tv on/off switch crackled and died. Grateful for help.
Hi
Assuming that is a standard switch, the solution is to remove the bad one (dessoldering it from the main board) and replace with a new one with the same pins and functions. You had better to carry the bad one to the electronic shop to avoid mistake.
Sully
Sep 28, 2013 | Televison & Video
Treble died on Harman Kardon HK980
You can always call HK at (800) 422-8027. They will tell you their authorized repair locations.
Nov 29, 2017 | Harman Kardon Audio Players & Recorders
My magellan turned on one time and napped, crackled and popped and shows that it has loaded but it nothing will come on. I can't use it, what do I do?
If your unit popped and crackled, sound like something has blown internally. You will need to send the unit in for repair.
Jan 09, 2012 | Magellan Maestro 3250 GPS
2007 Toyota Yaris speakers aren't working
you must check the wiring it looks like some wire are damaged their connection to check the wiring you need the wiring diagram which will help you to locate the problem go to the given link you can get the diagram from the link it's a safe and secure link http://toolsnyou.com/
Aug 22, 2017 | 2007 Toyota Yaris
Sound from my speakers is crackled or distorted. when I play music, at start it's working well..then afterwards there is a crackled or distorted sound...then return to normal...
Try updating your sound card audio driver and that would fix the issue.
Also install the KLite Codec pack which will enhance your audio and Video quality and also will allow you to play any video and audio formats
You can download KLite codec pack by simply searching it on google.
If you need online technical support, you may very well contact TheBestPcDoctor. I get my all issues fixed by them and it is a reliable support according to my experience. If you want you can also get in touch with them @
www.thebestpcdoctor.com or via 877-407-9229
Please Rate if you find it useful
Sep 04, 2011 | Acer Audio Driver Realtek.exe
Computer just died.. no lights whatsoever. power
Take out the battery and try to start from the charger - if it's the same then you had a major hardware failure , most likely your motherboard has died. You need to take it to a repair shop for a precise diagnose and repair.
Jul 31, 2010 | Toshiba Satellite A215-S7422 Notebook
Both ovens stopped working
good day,
hope this link below will solve your problem.
ovens
May 03, 2010 | Maytag CWE5800A Electric Double Oven
My CRT Samsung TV crackled at the back and the picture died! Could be a capacitor gone. How much would it cost me to be repaired?
it might depend on how badly affected the board is. But a usual cost is close to $350 Varies with some contractors and distance traveled to repair site.
Please rate our help to keep the FREE service online ++++ Thank you for using FIXYA
Sep 03, 2009 | Samsung WS32Z308P 32" TV
I HAVE A 32 INCH SONY TV AND NOW I HAVE SOUND BUT NO PICTURE WHAT IS THIS
If you still have sound, part of the main power supply is working so the problem is restricted to the deflection-related circuits and probably in the horizontal oscillator circuit responsible for producing the high voltage for the CRT as well as the horizontal deflection. Since it died to a 'dot' the vertical deflection circuit may also be supplied by the action of the horizontal circuit. You will need technical help to restore it.
If you had good picture quality before it died, I would recommend having the set repaired and if and when you decide to buy a new set, store this one (repaired) along with a converter box (for the new digital signal) to use when the new set dies, which it will and much sooner than your Sony.
Apr 22, 2009 | Sony KV-32S45 32" TV
MSI P4M900M-L (7255-060(P4M900M-L)) Motherboard Logo
104 people viewed this question
Top MSI Computers & Internet Experts
Ekse
Thomas F. Schneider
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
