Question about Sony Bravia KDL-26L5000 26 in. LCD HDTV
Sony bravia works on ups/battery not mains :(
Guys here the problem: a month ago, there was a huge power surge and thick smoke came out of my sony bravia lcd...i turned it on after a while and it worked fine....i was surprised as to how it could work..i asked a support guy n he told something about some power surge liquid inside it and blah blah..i honestly didnt understand him...he told theres no problem and it worked fine for a month n now yesterday, the picture started scrambling...it was like...every 2-5 seconds,it would say no signal..picture would come for a few seconds and again it would say no signal...after a while ,the tv would turn off(not standby,just off).... and another peculiar part is,we use inverter/ups at home..when its connected to just ups, works fine!! when its on mains,the problem occurs.. can anyone tell what the prob could be? the tech guy on phone told cud be a capacitor issue but im worried whether its some major problem.. pls tell : 1. what is that "power surge liquid " the tech guy was teliing about ?or what do u think really happend when smoke came? how did it still run?? 2.what could be the current problem? UPDATE : i tried turning it on a few mins back,now it wont turn on at all! it used to work fine on ups..now even the red light doesnt come...i can see its drawing power as i can feel its load on ups...HELP :(
Posted by anman_chill on
Sattech
  • 22 Answers
Sure sounds like the power supply board received an insult that allowed a different voltage to work for a while . UPS will regulate top 120 volt whereas mains may be higher or lower . You may be able to change bad capacitors or just buy the power board between 80 to 200 dollars .
If it was connected to UPS during surge it should have been protected...make sure you are connected to 'battery' side as a lot of UPS have a 'surge only' side that will not stop a rapid on/off power insult .
Hugh
Posted on Mar 11, 2017
5 Related Answers
Anonymous
SOURCE: audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Posted on Jan 15, 2008
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: flashing red standby light
Take it down from its mount and try to restart it if this resolves the issue your mount is too tight on the back of the lcd monitor.. This happend to me as well good luck with your BRAVIA
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 22, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony KDL-46V3000 Bravia LCD Black screen
Please count Sony KDL-46V3000 standby light blinks as there would be interval of 3 seconds between blinks. Let me know how many times light blinks as its an error code.
Posted on May 17, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony KDL40S2010 Bravia LCD TV... turns off / on on it's own
If TV does not remain in standby and turns on itself then power switch on top of it could be defective and power supply board is also suspected. Take off its back cover and unplug top switch connector just to confirm is that cause of On-Off its own. If problem still exist then power supply board has problem and will be replaced. Let me know the results to move forward.
Posted on Jun 13, 2009
Anonymous
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
Sony bravia no tv signal but video okay
Check and replace its tuner. Contact any service technician. This is not a user repairable work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 16, 2014 | Televison & Video
Hey i just bought a new sony bravia hd lcd internet tv. and ever since like a month ago the screen would go blank and the volume would go out. the screen would only go out for a few seconds but its enough...
Tv it is having a problems,it is developing a power surges to their eclectronic boards.If this tv have this problems like 2 or 3 times black out in a couple hours of tv watching?Yes.This is a brand new tv?Yes,it should be return to the place where it was bought right away to exchange it for another tv,because this problems,will develope in to a bigger problems.The tv Tuner signal board,will evenually will dies completey.After tv life in usage for awhile more.Ur tv evenually get power only, indication LED power light up only,but no tv incomming broadcasting picture to tv at all.
Apr 17, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia kdl40S504 has green ghosts - cannot
I do not think that cause by power surge, and it is on manufactory warranty, you better to call Sony.
Jun 26, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Power Outage Problems Sony Bravia 32" LCD TV
try cycling the power (unplug 2 minutes) and plug in and wait 30 seconds and turn back on. if this doesn't work, could have been a surge, your protector should have saved it, but could have been through cable or something. surge protectors will guarantee no damage for several years, check with the manufacturer maybe they'll cover the repair.
Jun 01, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sound doesn't work on television Worked fine yesterday but it isn't working today. I know the power went out briefly(few seconds) today.
Check a different input and all the connections to the TV to see if they are secure. After doing so and you still are getting no audio from all inputs then it means the audio processor failed. It was most likely caused by a power surge when the power went back on. This is fixed by replacing the main board. It is usually called a BU or AU board on Sony LCDs. Can be prevented in the future with a good surge protector or clean power surge filter.
Oct 07, 2009 | Sony Bravia KDL46V4000 46 in. LCD TV
I have a Sony Bravia XBR 46". It is 18 months old. The left 20% of the picture is fine, but the right 80% flickers in horizontal bands. Pushing back lightly on the upper right corner of the bezel and...
Please make sure that the connections are secure.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Please try connecting the TV to a different wall outlet and check if that helps.
Jun 19, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
SONY BRAVIA KDL-40s4100 is not working right
Please check whether the connections are secured between the TV and the connected devices.
Try connecting the TV to a different wall outlet and check if that helps.
Please connect a different device to the TV and check whether the issue persists.
If the issue still persists service of the TV is determined.
Jun 18, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony bravia 46" remote control turns on the TV but no other buttons work
First, change the batteries on the remote with e new set of batteries. Check to see if you can bring up the menu using the buttons on the TV itself. Let me know what happens
Sep 25, 2008 | Sony BRAVIA KDL52XBR2 Television
Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Sep 08, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia KDL-26L5000 26 in. LCD HDTV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
