Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
My hotpoint aquarius fdw60 won't work it done a wash but when i checked the wash everything was clean but it hadn't drained i have tried resetting it turning it of and on but it does nothing o
Posted by kenny folland on
Kenneth Simmons
  • Hotpoint Master
  • 1,139 Answers
Https://www.espares.ie/advice/careandmaintenance/hotpoint-dwf50-dwm55-and-fdw60-dishwasher-error-fault-codes
I have no dish washer but maybe this link may give some help.
It talks about your machine may be giving you a fault code which could help narrow your search.
Posted on Jan 07, 2018
5 Related Answers
Richard B
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Posted on Mar 23, 2008
Paul Davies
  • 157 Answers
SOURCE: HOTPOINT AQUARIUS FDW60 ECO LIGHT FLASHING
Check pump is running
Posted on Dec 19, 2008
Sam
  • 3247 Answers
SOURCE: Please help I have a aquarius FDW60 . The problem
It is likely the flood switch at base of dishwasher has activated due to a leak.
You will have to dry the leak and then try again.
Make sure the mains power is shut when you are working on the dishwasher to avoid electrocution.
Posted on Mar 16, 2011
Gerard Curran
  • 114 Answers
SOURCE: our hotpoint fdw60 won't wash
AL10 means open circuit in heating circuit. ie not heating which will also explain poor wash results.
can be a fairly involved job and should be left to someone who knows what they are doing.
on other hand could be as simple as a broken wire inside the door skin, just remove and give all the wires a good tug.
Posted on Jul 11, 2011
Ivan Storm
  • 32 Answers
SOURCE: Hotpoint Aquarius FDW60 won't take in water. Suspected airlock after house move?!?
Try checking the inlet solinoid , should be 1 for hot & cold, sometimes the solinoid will freeze up due to alkaline buildup .try soaking it in CRL , alkaline deposit desolving liquid .
Posted on Mar 13, 2012
Water not draning
If kitchen side drains are clear then there might be some blockage in the pump system. Check the drain pump is working during drain cycle. If you can hear the pump but the water does not go away then you need to check filters at base of dishwasher. Beyond that you will have to open the pump assembly to look for debris.
see these instructions which might be helpful.
http://jdesbonnet.blogspot.com.au/2010/11/hotpoint-aquarius-fdw60-drain-pump.html
Apr 04, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Mar 13, 2012 | Hotpoint 24 in. FDW60 Free-standing...
Mar 16, 2011 | Hotpoint Dishwashers
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Mar 18, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Will not desolve the tablet
is it heating if so check spray arm and filters are clean it is washing i take it.....
Sep 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dish washer aquarius
I had the same problem with my Hotpoint Aquarius the eco and fast light flashing, it would go through the pre wash cycle and stop.
I cleaned the filters etc; and it still didn’t work.
I turned the machine off and unplugged it at the mains,
I drained all the water, turned the machine on the side and took the bottom off, I removed the drain pump off the bottom (this was held on with a single screw after taking the screw out slightly turn it to one side as its like a bayonet fit on a light bulb also remove the wire connection and a rubber drain pipe)
Once the pump was removed I could clearly see the impellor it was very tight and I couldn’t spin it after a closer examination I could see a foreign object jamming it I removed this with a pair of tweezers, replaced the pump and put it all back together and it now works perfectly.
I hope this can be of some help.
Peter.
Aug 26, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
340 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
