Question about Kingston Digital DataTraveler 4000 8 GB Flash Drive DT40008GB USB Hard Drive
Loaded my 8G Kingston USB. Next day, properties says zero files, zero free space
I loaded my USB w/ 2 files. Next day, no more files were present and the device says zero free space but zero files. Tried reformatting but no dice.
Posted by jenferam on
Col Dana Gillespie
    Scholar:
  • 88 Answers
Which ever it sounds like it has been exposed to a magnetic field, like a stereo speaker.
Gillight
Posted on Jun 24, 2012
5 Related Answers
Beni S-P
arben pllana
  • 1006 Answers
SOURCE: Can't detect my HD properly
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Oct 26, 2007
Anonymous
SOURCE: my 8GB KINGSTON STICK PEN
not detected
Posted on Aug 07, 2008
Anonymous
  • 11 Answers
SOURCE: 8GB Kingston Data Traveller only has 101mb available!
Hi Cristina,
This is Azeem Inam. your data traveller does not accept data over 101MBs. There can be two reasons for this problem. 1. there may be a virus that has provided a limitation on the copying facility. 2. This can be a partition problem. All you need to do is to use the software called DM (Disk manager). This is a DOS versioned software. Go into its advance installation option and then accept the hard disk kingston data traveller. It will take you to another menu showing the partition styles you may choose. you'll have to choose FAT32 type. then in the next menu you'll have to choose partition size by pressing enter button. and then accepting format you are done. it will start working as new again. Thanks for consulting your problem.
Posted on Feb 13, 2009
Anonymous
  • 100 Answers
SOURCE: Verbatim 8G drive removed without clicking device
thats the best sulotion reformat the drive and recover all your files by power data recovery software download this software give me your email. i will send you a copy for this.
Posted on Nov 10, 2009
jncojr
Tech Guy
  • 47 Answers
SOURCE: Describe your kingston usb repair tool Problem
Plug it into the computer, go to My Computer, right-click your USB drive and format it with the files system as FAT.
Posted on Mar 14, 2010
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
Each time I try to open, I cannot and they tell it's full
click start right click on my computer you should see your usb drive right click on the usb drive select properties you will see the ammount of data used and the free space
hope this helps
May 08, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My kingston usb says it has 7 gb free, but when i copy a movie file of 5 gb it says there isn't enough space.
is it a 2GB or a 7GB Kingston USB drive
control panel admistrive tools,computer management disk management right click on your drive select properties click tools you should see two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when resart
hope this helps
Dec 04, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have 8gb kingston pendrive..and i set my pendrive drive name to 'myname'.i already used my pendrive 7.4gb.and got a lots important files..when i plug in the pendrive,it will automatic install driver...
yes your pendrive is attactked by a severe virus.......you need format it you can do only one thing click on format option or restart the pc then press f8 thenan stat windows setup when you reach the formatting option then only format that pendrive.............
Nov 27, 2010 | Computers & Internet
My pen drive is of 2GB i dont know how but now it showing 1.50GB as used space and only 500mb odd free space and its completely empty,there is no data inside plz solve my problem
Insert the USB stick in your computer, then go to "Start" then "My Computer", locate the USB icon and right click and select "Properties". From there you can do a format of the stick. This will erase all the data including some hidden files that you might have and solve the problem.
Note that even though it says 2Gb, the data you can use is slightly less. This is true for any storage device out there.
Nov 10, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a 4 GB kingston USD pen drive when I try to save data It says no space
Good Day!
See first the free space of your Pen Drive, to do this, go to MY COMPUTER then right click your PEN DRIVE and click properties, you will see how much is the available space. And also try to see the file size that you are copying and compare it to the free space of your Pen Drive. You can't copy file more than the capacity or the free space of your Pen Drive, that is why you come up with that error message.
Hope I was able to help.
Jul 16, 2010 | Kingston 4GB Secure Digital High Capacity...
My 2 gb usb kingston can't open files. not formatted
Sound like it is infected with virus. Find a computer with a good Anti Virus and Malware Program. Go to My Computer and right click the USB drive and select the Anti Virus program that shows on the list.
When scan is completed, right click the USB drive in My Computer and select Properties then select Tool and then click the Check Now tab.
Next check the two brackets and click start.
Should be good as new after.
Regards
Feb 25, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Not able to copy more than 1GB into 2GB Kingston SD card
Hi 1123sun,
Copy your files off the card. Then Format the card and select FAT32 file system. After the format is done try the card again and see if you can copy more files to it.
Kingston Tech Support
Feb 18, 2009 | Kingston 2GB Secure Digital Memory Card
Kingston Digital DataTraveler 4000 8 GB Flash Drive DT40008GB USB Hard Drive Logo
111 people viewed this question
Top Kingston Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Mike
Harish  Ramaiah
Harish Ramaiah
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
