Ink motor is working in test mode and pump is also good
SOURCE: WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
SOURCE: copy problem
i think that u have pending work out there!
look in ur task bar n u'll c the icon - right click on it n u'll c all ur pending work!
u hv 2 cancel or restart ur pending jobs!
BUT the best solution is to press the cancel key 'X' on ur printer after loading papers into ze tray!
HOPE it'll work n blinking will stop!
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
has the unit been used regularly. The ink unit is locked in properly and handle locked.
