SOURCE: Installing windows XP - Error encountered
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
SOURCE: Recovery Error
Do recovery again, when it asks you to insert disc 2, take out disc one and close the tray. Do not put the disc 2 yet. If you can see the error message again, then it is a RAM issue. You need to reseat the Memory module and try to do the recovery again.
If you closed the tray then no error message came up, it would be an issue with your recovery disc and order for a new one. You can contact Toshiba to have the recovery replaced due to corrupt media.
Hope this helps.
SOURCE: Won't Boot up
im having a wierd problem my toshiba error 03-EEEE-0000 happened right after MYSTICALLY my atheros wireless wouldnt work so i formamtted wen i put in any windows CD it says BAD COMMAND.. same with recovery PLEASE HELP
SOURCE: error 08-0E89-0000 satellite A215 S7425
Can you get into your computer at all?
If you can please could you do this, go to command promt, this is usually in all programs/accessories. And then type in chkdsk c:/f, hit enter.
Karlos
