Question about Kodak Cameras
Memory issue Its own internal memory works fine but when I put a new sandisk 4GB sdhc class 4 into the camera It asks me to format it. so when I continue to format, it says memory card unusable [insert new memory card] so i tried using a micro using an adapter and got the same resaults. Does this sound like a camera issue or memory?
Posted by Victor on
  • Victor Jun 25, 2012
    Its a M1073IS
    Its a 10 megapixal camera
Shajan RS
  • 890 Answers
Please confirm the model # so that I can check whether the large capacity memory cards are compatible with your camera.
Posted on Jun 24, 2012
5 Related Answers
Anonymous
  • 39 Answers
SOURCE: Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
Posted on Nov 28, 2008
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: SDHC card won't work
firstly does the camera support 8GB? if it does the card may have the "write protection" switch on, take the card out and check this, after you have checked it put it back in the camera and format the card using the camera menu
kind regards
Posted on Dec 22, 2008
Anonymous
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
Anonymous
SOURCE: I put a 4GB Sandisk SDHC card into my Panasonic
no way to solve...only SD is applicable...4G SDHC is not suitable for it
Posted on Jun 13, 2009
Anonymous
  • 73 Answers
SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
your sd card is sadly corrupted if you downloaded the pictures to your computer your in luck then get a new sd card and download all the pictures from the computer if its a labtop put the sd card on the bottom hope this helped vote thumbs up for more answers hope this helped
-Yashar G.
Posted on Aug 24, 2009
NEED TO TAKE OFF WRITE PROTECED ON SONY SDHC 4GB..
There is red colored switch aside ur memory card. check it if its locked mode,then push it upwards and make it visible.
Dec 11, 2012 | SanDisk 4GB SDHC Memory Card Class 4 w/ 25...
I bought a 8gb class 4 sandisk sdhc card, it worked fine for a few minutes. I transferred my pictures off my blackberry onto it and it still worked. Then a few minutes later I cannot access my media card...
This question is posted in the digital camera section and I think we are taking about a BlackBerry Phone. If it a phone you are attempting to you that wicked high tech SDHC class 4 memory card in I believe that's the problem. Your phone just doesn't have the software to support that massive card.
It's the phone programing not compatible with the SDHC card. Another thing also is you need to format a memory card in the camera/device you are going to us it in. Formatting the memory card in the computer and then putting it in the camera/device will just cause an eternity of errors.
Did you go into camera options on you BB and make you switched from the BB internal memory to media card?
other then that I'd say the card is beyond the capabilities of the BB
Mar 08, 2011 | SanDisk 8GB Ultra 15MBs SDHC SD Class 4...
I have a SanDisk SDHC Card class 4 4 gb and it won't work in my Canon Power shot SD630, I get a memory error that says card is locked, however card is not locked, what camera canI use this card in?
The SD630 works with MMC and SD cards, 2GB or smaller. It does not work with higher-capacity SDHC cards.
Your SDHC card can be used in any camera that accepts SDHC cards.
Feb 03, 2011 | SanDisk 4GB Secure Digital High Capacity...
4GB Sandisk is write protected; I don't know what I pushed to do that, but now I need to unlock it so I can use my camera. Please help
On the side of the SDHC memory card is a sliding lock I have a diagram to show where this is and which direction to push the slider. Here is the diagram.
Also to make the SDHC work compatible with your camera you need to format the memory card. Each time you download the picture files the memory card needs to be formatted, never format in the computer and expect the card to work in the camera.
Dec 27, 2010 | SanDisk 4 GB Standard SDHC Card with Rezo...
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Cameras
Canon Legria HF200 SDHC Initialization problem
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok.
I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
Apr 12, 2010 | Canon Legria HF200 Flash Media Camcorder
I have reinstalled the software several times.
1. Get a memory card. 2. Format the new card in the camera. 3. Go into the camera menu and find an entry for "copy" or some similar topic which would allow you to copy the contents of your internal memory to your new memory card. Once the pics are on the memory card, you should be able to download them to your computer.
Dec 10, 2009 | Fuji Cameras
I put a brand new SanDisk SDHC 4 GB memory card in and it says "memory card error; card is locked".
I also own an A620, but unfortunately I also learned the hard way that SDHC cards are not compatible with this camera. The A620 was designed before the newer SDHC format came out, thus although they look exactly the same, your camera will never work with these cards. Your camera uses standard SD cards (2GB or less). There are some standard 4GB SD cards, but they are very rare these days, and costly.
Aug 06, 2009 | Canon PowerShot A620 Digital Camera
Cameras Logo
Top Kodak Cameras Experts
Steven Wander
Steven Wander
Are you a Kodak Camera Expert? Answer questions, earn points and help others
