Tv wasnt on during storm, was on a surge protector. Ant A and B have "snow" sound so the speakers are't fried but all other inputs (dvd, dtv, xbox) have no sound. Went through setup so all settings are correct
Ok, a long time expert and person who has repaired a lot of these sets.
This set has 3 hidden menus: adjustment (stay out of that one), convergence, and the OPTION MENU----THAT ONE CURES ALL SORTS OF ODD ISSUES--it requires the original Mitsubishi remote and a 4 digit code to enter.
It will if used reset the set to factory in all respects except for convergence which is stored elsewhere.
Seen a number with no sound, no inputs etc that it cures.
Let me know and I will get you a link to the service manual for free if the site has this one(I think they do).
10 minute job and point and click---what likely happened is the micro in the set became confused--happens a lot and reason the Option menu is there.
That sounds promising and very helpful. Thank you. Where do I get the 4 digit code?
Here is a link to the full service manual--download is free or you can view it only--has a lot of good information---PAGE 23 has instructions for the Option Menu.
http://www.scribd.com/doc/63954077/Mitsu...
the process if done correctly is defined in those instructions--set should come back on channel three in the air band----other than the option menu look for speakers being switched on---you may have a failure in the audio circuit presuming no sound on any input like the tuners or with a DVD connected via one of the rear audio/video jacks.
SOURCE: Power went out during recent storm. Have a power
Very common problem caused by failed DM capacitors. You can get the DM repair kit for your model from www.tvrepairworld.com the kit does come with instructions.
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Picture quality is perfect, just no sound from speakers with dtv,dvd xbox input. When input is switched to antenna A or B "snow" sound will come out of speakers so the speakers arent fried. Took dtv, dvd and xbox to another tv and sound works perfect. Checked all settings (sap, speaker settings, mute setting) and all are correct. This happened after a thunderstorm with power flickering. Tv was not on during the storm and was plugged into a surge protector.
Still no sound. I assume you do nothing after clicking on initialize once its highlighted? I checked for trouble codes and it flashed 12, which is no fault. Are there any other diagnostics in another manual than that one? All that seamed to have was adjustments for the picture. Thanks
