Question about Dell Inspiron 4000 Notebook
Wireless adapter does not work
My laptop keeps telling me that there are no available networks even though I am right next to my router. it says that network adapters on my laptop does not work because of error code 31
Posted by Dayna Ford on
paul
    New Friend:
  • 59 Answers
There is no driver installed for your adapter. check in device manager click on network adapters.you may have to connect to internet with ethernet cord before you can download a driver for your adapter.
Posted on Jan 11, 2015
5 Related Answers
Anonymous
  • 1067 Answers
SOURCE: Latitude D600 Network problem
unplug roughter then back in after 1 min and modem ok then rebooot give it a min
Posted on Jan 20, 2008
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
Posted on Feb 03, 2009
Anonymous
  • 52 Answers
SOURCE: Dell Inspiron 6400 - Wireless Adapter Problems
Broadcom is not wireless, but the normal ethernet controller.
You should go to intel / your laptop manufactuer website and download the appropriate drivers.
Posted on Mar 21, 2009
Anonymous
  • 5 Answers
SOURCE: dell wireless 1395 adapter not work on my laptop
Uninstall the existing drivers in device manager (RH click on my computer, go to manage, device manager.)
Go to
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R174292&SystemID=INS_PNT_PM_1525&servicetag=&os=WLH&osl=en&deviceid=15680&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=236824 (PASTE THIS LINK INTO YOU BROWSER)
Hard Drive Installation (via WinZip) with Setup.exe File for R174292.exe
Download
1.Click Download Now, to download the file.
2.When the File Download window appears, click Save (Windows XP
users will click Save) this program to disk and click OK. The Save In:
window appears.
3.From the Save In: field, click the down arrow then click to
select Desktop and click Save. The file will download to your desktop.
4.If the Download Complete window appears, click Close. The file
icon appears on your desktop.
Install
1.Double-click the new icon on the desktop labeled R174292.exe.
2.The Self-Extracting window appears and prompts you to extract or
unzip to C:\DELL\DRIVERS\R174292. Write down this path so the executable (I.e.
Setup.exe) file can be found later.
3.The Self-Extractor window appears.
4.Click OK.
5.After completing the file extraction, if the Self-Extractor
window is still open, close it.
6.Click the Start button and then click Run.
7.Type C:\DELL\DRIVERS\R174292 in the Open textbox and then click OK.
8.Follow the on-screen installation instructions.
Posted on Apr 17, 2009
Anonymous
SOURCE: Dell Inspiron E1505 will not connect to wireless network
to turn on press the FN button and the F2 button at the same time and you will see the wireless light go on. then you will find a wireless signal.
hope this helps.
Posted on Jan 11, 2010
My Belkin Wireless Adapter connects to the router but says there is no internet connection on my laptop even though there is when I connect to a hard line. All wires have been checked and other items are...
check what encryption your laptop will work with, if its an older laptop then its probably only 64 bit and your router is running on 128 bit encryption, and this will give what you have connected to router but no internet connection
I have an excellent connection to city wifi but no web page.
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
2helpful
Laptop not connecting to wireless network
Don't wait tell you laptop is defective, at least buy a new wireless lan before its too late.
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Can connect via Ethernet but not wireless
well its unfortunate,,intel 2200 WLAN cards{oldest cards launched till now by intel} face this problem,the problem is with the differnce of wireless standards between the router and the wireless card.go for a wireless usb adapter,,install it and it wud work absolutely fine
1helpful
Wireless light on router is off and don't have an online connect
First off, go to your Start Menu. Next, click on Control Panel, from there, click on Network and Internet Options. Next thing you need to clik on is Netwrok Connections. From there, check to see if your internet is even connected. If it says it isn't, try right clicking on that connection and then click on Repair. Hopefully this will fix your problem.
My desktop uses a DSL internet connection but my lap top will not pick up the signal from it to connect even when I have it sitting right next to my desktop. If I actually unplug yellow connection cord...
Having your laptop sitting next to your desktop will not let your laptop connect to the DSL link.
You need what's called a Wireless Router. (assuming your laptop has a wireless adapter, if not you'll need a network cable for that.
1. Go to the store, buy a wireless router
2. install router in between your DSL modem and the computer.
3. Plug the WAN port into the DSL modem (cable is usually included with the router)
4. Plug the desktop into the back of one of the ports of the wireless router
5. Run the setup disk
6. For manual configuration of the router you can usually go to: 192.168.0.1 or 192.168.1.1 or 192.168.2.1 depending on the brand)
7. If you don't know anything about networking, let the install disk do all the work.
8. Follow the instructions on what it tells you your configuration is for your wireless network.
9. Go to your laptop, apply said instructions.
10. ???
11. Profit.
How to connect wireless router, Netgear WGR614, to my computer?
4 steps to set up your home wireless network
1.
Choose your wireless equipment
The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
• Broadband Internet connection
• Wireless router
• A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2.
Connect your wireless router
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
wireless_chart.jpg Next, connect your router to your modem:
WIRELESS NETWORKING
There are several problems reported that may cause disconnection. First is the hiding of the SSID (wireless network name) and enabling WEP or WPA encryption. The recommended solution for that is to unhide the SSID in the router configuration.
Second is that there are more and more wireless devices and occasionally interference occurs on a single channel (even from non computer devices like wireless phones. As routers are often set to channel 6 you may be competing for radio communications with your neighbors. The recommendation is to switch the router to either channel 1 or 11. If your first choice does not work try the other.
3answers
My laptop cannot connect to my local network (LAN)
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
Dell Inspiron 4000 Notebook Logo
Ekse
Mandeep  Singh
Mandeep Singh
Michael Thomas
Michael Thomas
