Star CG14 Indoor Grill Logo
Question about Star CG14 Indoor Grill
How do you change the temperature setting on a star pro max panini
Posted by jfhevesi on
1 Related Answer
kebah
Angel Joseph Jr.
  • 685 Answers
SOURCE: I need the owners manual
Check the Star products/ manuals at www.middleby.com
Posted on May 22, 2011
Manual for Breville BGR200XL Variable Temperature Panini Grill
Hello Kevin, I have a link to the manual online. It can be downloaded in pdf format or you may view online. Here is your link.
http://www.breville.ca/media/mediaappearance/4528/BGR200XL_IB_B13_FA_LowRes.pdf
International 2010 pro star with the max force engine
You can order a manual from the dealer parts department or find one online through numerious forums
Panini grill not working
Hi, sounds like your element blew. you will need to contact your local appliance repair facility for repair. There are no user serviceable parts...
Panini grill overheats
thermostat problem, need to change thermostat
Flashing green indicator lights
When the green light is flashing, it is not at the set temperature. It will be solid when temperature is correct. You are selecting grill or griddle and then turning the temperature knob for that selection? It's not working with either selected?
5helpful
The driver was not installed. You did not accept the certificate required during installation. (DTD8008)
We have got the same issue too when using the desktop deposit function.
The tech support basically did 2 things to resolve the issue:
  • In Internet Explorer
I need the manual for wolfgang pucks panini maker
MY COMPUTER WOULD NOT GET THE WEB PAGE TO PRINT IT, SO FRIEND DID iT FOR ME , AND i NOW HAVE THE INSTUCTIONS. THANK YOU ..
My Hotpoint WMA58 washing machine is not heating the water so the cloths are only getting washed in cold water. Will this be the heater element that has gone? If so how do you change it.
We had this problem & called our repair man in. We had accidentally knocked the 'Variable Temperature' dial down too low. It should ALWAYS be set to max (95). The programmer will still sort out the correct temperatures for the different programmes, such as cold wash, but setting that to whatever temperature means that that is the max it will ever reach, Since then, we have not had that problem again.
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
