SOURCE: dell e510 cd dvd rw not working
Try going into your Device manager start right click on my computer click on properties then click hardware tab. Under this tab click device Manager. Under disc drives find the drive that you are having problems with and right click on it. Then try to update drivers. If this dose not work do the same thing but this time uninstall the drive. After it uninstalls go to your controll pannel and click on add hardware. It should find and reinstall the cd rom and it's associated files and hopefully work once again.
SOURCE: Dell Dimension E510 memory upgrade
Please check the type of RAM you are using.
You must return it to BestBuy and try using a Dell store.
Call Dell Accessories sale and they will be able to give to better options and it wud work too.
SOURCE: my dell dimension E510
If the sound card is built in then go to Dell support site and download the drivers - if that doesn't work it is probable dead
replace it with a PCI card
SOURCE: Dell Dimension 3000 CD/DVD drives not working
You can download the drivers from dell website, download.com, and many other sites. Download, then double click on them to install them. Once installed, reset pc.
