Dear
You can try from samsung site.
Printer Support SAMSUNG India
Thanks.
SOURCE: Samsung ML-2510 both lights blinking fast beware spammers at 1*800*532*4187
I noticed that the orange cancel button was jammed down. I couldn't prise it up, but was able to release it by tapping firmly the top of the printer near the button. As soon as it popped up - the buttons stopped flashing
SOURCE: Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
• A minor error is occurring and
the printer is waiting for the error
to be cleared. When the problem
is cleared, the printer resumes
printing.
• The toner cartridge is low. Order
a new toner cartridge. You can
temporarily improve print quality
by redistributing the toner. See
page 8.3.
• The toner is totally exhausted.
Remove the old toner cartridge
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
SOURCE: need instructionson how to refill an ml-2510
Try this site, it might be useful
http://www.manualnguide.com/download/manual-guide/samsung-ml-2510xaa-mono-laser-printer-user-manual.html
SOURCE: Have you found a solution to the Samsung ml-2510
There are a couple of reasons why this happen. A paper jam could have occurred. The cover might be open, try closing the
cover. There might be no paper in the tray, load paper in the tray. The toner cartridge is not installed. The printer has stopped printing due to a major error (you need to contact your manufacture for this).
SOURCE: Samsung ML-2510 printer paper jam
This happened to me after I had cleared a paper jam. I finally had to take off the back and cover to discover that there was, indeed, a small piece of paper invisible otherwise (torn off of the paper I removed). I removed the piece with tweezers and now it's working fine. Remove all other moveable parts inside. The top front is held on with two plastic posts + screws, the back by four deep-set Phillips screws. Might work best to remove back screws, then front, then top. The top feels fixed, but it snaps out (sounds loud!) with some pressure, and snaps back in on reverse. Harder to replace than take off.. Be sure the light color on the top on either side of the fuser opening slides under the darker color part of the back (about an inch?) before snapping or screwing it all back. Good luck!
i need firmware samsung ml-2510 printer for download
