I washed it by acident now after 4 mounts of letng it dry when i plug it in it show red light for charging then 3 min. later its green and dos not power up after being unplued
SOURCE: WONT TURN ON!!!!
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
SOURCE: Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
SOURCE: Samsung YP-K3 MP3 Player won't start
I've two simple solutions!!!
1. It's like what everyone says, you push the Reset button on the back and plug it in again. Did not work for me though. :(
2.
I used this solution instead, I went to Control Panel > Performance
& Maintenance > System Open the drives tab and and looked up the
mp3's drive. I saw there was a yellow exclamation mark. I then right
clicked on that drive and updated it. Voila, it updated the MTP, and
DONE! MAGIC! ;D
I hope it works for everyone, good luck!
SOURCE: I can't seem to turn on my Samsung YP-T7J MP3 Player
on the bottom of the mp3 player there is a very little button that u need a needle to push its the reset button sometimes these mp3 freeze and u must push the reset button it u dont loose any music or saved files anything like that it just basically turns the mp3 player off for u so that u can then turn it on using the play and pause button on the side of the mp3 player if this doesnt work the i guess tuff nooges
SOURCE: My Samsung YP-T9 MP3 Player wont turn on!!
I think holding down menu and the record button at the same time should fix it. I read the best solution and it just turned on. I was having the same problem, mine would not turn on either but just try pressing and holding down the record and menu button for about 5 seconds.
