Unit powers on audio starts to play then is a few moments error message on display AMP Guard and audio stops but unit remains powered on.
SOURCE: Volume issues with clarion M309 installed on a boat
Hello jcox7704,
Your head unit is 50 watts X 4 channel maximum power and 21 watts RMS so it's possible that all you need is more power to the speakers. But even 21 watts RMS should be enough for normal speakers. Before investing in an amp, I'd check the speakers and their wiring. Measure the impedance (resistance) at the head unit side to see if they match up.
Hope this helps.
SOURCE: amp guard
This is the mesage it will display when a short in a speaker wire or
speaker with low impedence is hooked to the internal amp and sends it
into protect mode, shutting down the amplifier section while the rest of
the unit continues to work.
check all of your speakers are not touching metal
SOURCE: clarion dxz545mp amp guard
, the message you are getting is "amp guard". This is the mesage it will
display when a short in a speaker wire or speaker with low impedence is
hooked to the internal amp and sends it into protect mode, shutting
down the amplifier section while the rest of the unit continues to work.
SOURCE: clarion dxz545mp amp guard issues
SOURCE: Clarion CZ500A won't power up. Following error
Hey Adricat, did you get a solution to this problem? I have had this happen twice now, and each time it was replaced by the shop i bought it from.
