Question about OKI C Office Equipment & Supplies
SOURCE: Oki c5500n drum reset
To get the OKI C5500 to keep going (without opening and closing the lid constantly) in spite of toner cartridge & drum life messages:
1) Turn off printer.
2) Hold down "+" and "-" buttons at the same time, and keep them held down while turning printer back on... continue to hold until the word "OKIUSER" appears.
3) Use "-" button to scroll down to "FUSE KEEP MODE".
4) Press "Enter" button, hold for approx. 10 seconds, then release.
5) Press "Enter" button again, followed by rapid release and repress with hold for approx. 10 seconds.
6) Release "Enter" button, then press and let up one more time quickly.
7) You will see "INITIALING" and then "ONLINE" messages.
If you currently have an error message for toner cartridge life, the message will continue to be shown until after you've sent one print job, and then it will usually disappear for awhile. It will stay gone for longer if you have your printer set up so the toner sensor is turned off.
If you currently have a error message for drum life, it will continue to appear, but you will still be able to print.
Beware that you will have to keep a closer eye on print quality (since you are no longer relying on error message to tell you when your toner cartridges are in need of a replacement or refill, or the drum truly needs to be changed or refurbished).
Please note that anytime you turn the printer off, you will have to go through the whole process again when you turn it back on. It doesn't take long though, and will quickly become habit whenever turning on your printer for the day!
Good Luck.
Posted on Apr 08, 2008
SOURCE: OKI c5600 drum reset
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
Posted on Apr 20, 2009
SOURCE: oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Posted on Jul 09, 2009
SOURCE: How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum
the machine resets the counter and then blows the fuse. So if the unit
is ok and you just wish to run it through another cycle just change the
fuse.
This means you cannot just put a full unit in from another
machine as it will not reset the counter until you put a new fuse in it
as you found out.
This applies to drums transfer belt etc.
Note
with regard to refilling the toner, some printers have 2 sections. 1
where you put the fresh toner and an after collection section in the
same unit. You must empty the 2nd section if you refill it more than 2
or 3 times
Posted on Oct 07, 2009
Testimonial: "Great fast response."
SOURCE: resetting image drum after replacing for oki b4600
Posted on Oct 30, 2009
Nov 26, 2015 | OKI C3400n Laser Printer
Jul 23, 2014 | OKI C Office Equipment & Supplies
Jan 28, 2014 | Oki Electric Industry C8600n Led Printer
Jul 05, 2012 | Oki Electric Industry B431d Printer
Feb 11, 2010 | OKI C3400n Laser Printer
Jan 14, 2010 | Office Equipment & Supplies
Oct 03, 2009 | OKI B4600 Printer
Sep 15, 2009 | OKI C3400n Laser Printer
Jun 19, 2009 | OKI B4600 Printer
Apr 20, 2009 | OKI C5500n Printer
1,486 people viewed this question
