Question about Microsoft Windows XP Professional Edition With Service Pack 2 for PC
Computer says it is in save mode
8 year old dell computer will not stay on. Maybe coincidence, but it started right after two year old pushed a button on the monitor
Posted by pamela leisinger on
Brian Sullivan
  • Microsoft Master
  • 27,725 Answers
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Posted on Jun 22, 2012
1 Related Answer
Anonymous
  • 76 Answers
SOURCE: Windows XP in Power Save Mode and no buttons get it out
This can be solved in either of two steps.
>There should be "SPECIAL KEY" in the keyboard labelled as "SLEEP" or "STANDBY"...try clicking it..
<or>
>Check the monitor ON-BOARD settings for "POWER SAVER MODE".
Hope this will solve u r problem..
Plz revert back for any queries.
Posted on May 27, 2009
I have olds intrigue '98. Always ran great.
If you are saying it starts and then dies, have you checked fuel pressure again ? Could be the fuel pump relay.
Jul 30, 2013 | Cars & Trucks
Monitor stays in "Power Save" mode
if u r reples this monitor pls. call me dear
tek a new monitor from me same model
Nov 27, 2012 | Dell ST2410 Monitor
Dell inspiron elec cord isn't firm so power turns off
Maybe it's the DC Jack that the power cord plugs into. If the jack is loose then you will experience the issue you are having.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Apr 18, 2012 | Dell Inspiron 1525 Notebook
Internal microphone not working
I have Dell Inspiron 1520 and I have issue to built in microphone is not working. I tried to execute the Sigma Tel driver from Dell Driver and Support website but prompted 'Exit Error; Error : Device Object not present, Restart system and run setup. Then, asked Dell support to help and they are not really helpful, after System Restore and drivers upload and finally asked to reformat the laptop........
Anyway, this is what works for me.
1) Download the Sigma Tel driver from Dell Support Drivers page and save it in Desktop
2) Shutdown your computer
3) Start your computer and press F8 at the Dell Logo page
4) Select Safe Mode (not others)
5) Proceed to work on Safe Mode
6) Right-click the Sound icon and activate the Sound icon
7) Select Recording device.
8) If still not working, then execute the Sigma Tel driver that saved in desktop
then, shutdown the computer and start as normal, you may see the system able to detect the built in Microphone then.
Hope it will work the same for you too..!!
Apr 20, 2010 | Dell Latitude E6400 Notebook
How do I get into safe mode on a Dell Inspiron 531. PF 8 doesn't do it?I can only get into Setup with PF2. Otherwise the boot up only goes to the DELL screen and hangs there.
You cant get in safe mode because the PC hangs before windows ever try to start.
Try to press F8 multiple times but right after the Dell screen.
Some computer don't like that you press F8 while the bios is loading and just hangs there, maybe its your case.
Oct 27, 2009 | Dell Inspiron 531S (DDCWGA1_5) PC Desktop
How to start in safe mode Dell Optiplex GX 150
Is it booting to normal mode?
If it is booting to normal mode, click start - run and type msconfig.
Click on Boot.ini tab and Check Safeboot. Click Apply and Close or OK. It will restart the computer to safe mode. Remember to uncheck Safeboot to make the computer to boot in normal mode again.
Mar 21, 2009 | Dell OptiPlex GX150 PC Desktop
Hp w2007 blank screen
we have here , like 1000s of black screens posted here now.
all the same all with CCFL lamps. that die. same solution.
older monitors have a power saver mode inside it,
push the front button called menu, then see OSD menu
then find and turn off power saver.
if the OSD fails to show up; the CCFL are dead.
this monitor was made in 2007, and 2010 is the starting year
for ending the usage of CCFL (starting on large screens working to small)
im reading your manual for you now, free.
page 4 tells you it has CCFT (T mean Tube, L means lamp)
same same.
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=4#manual
now lets look at the page on saver. power
page 7, (its on by default ) oops !
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=7#manual
turn saver OFF
see next page 8 and turn DDC ON.
see sleep timer and turn that all off.
if you push factory reset, it the problem begins again.
bad. for you.
https://www.manualslib.com/manual/1110533/Hp-https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=8#manual
you can in fact download the whole manual.
for free. here. the site on the internet in this regard.
all old HP monitors are made for old PC 2000 year.
your PC is not 17 years old i bet.
so all this old saver stuff is now WRONG.
(all this is old school Energy Star , malarkey, )
Nov 13, 2017 | HP W2007 LCD Monitor
Problem in Auto adjust mode
Auto Adjust work on the basis of resolution to which Windows set. It occurs mostly if Video drivers are not installed. Please check and install video drivers and also try to change screen resolutions from display properties in control panel.....
Nov 06, 2008 | Dell E176FP 17" LCD Monitor
Microsoft Windows XP Professional Edition With Service Pack 2 for PC Logo
75 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
