Question about XM Radio (XMP6000)
Radio loses signal and blinks "loading..."
I've had my XM Radio for 9 months. It's an ExpressEZ installed in my 2008 Toyota Corolla. I've never had a single problem with it. 3 days ago, I turned off my car and the radio was working perfectly. When I came back to my car 5 hours later, the radio wouldn't pick up a station for more than 1 minute at a time, then it would lose the signal and blink "loading..." or "no signal". It never stays on any of these messages for very long. I called XM and they told me that it was a wiring issue, but I was skeptical, so I called my dealer and told me that it was definitely not a wiring issue. Can someone please help me??
Posted by fischer_444 on
  • 6 more comments
  • Anonymous Dec 04, 2008
    I have the same radio, and same problem. Problem started in about October 2008. XM tech support says I need to get the XM SureConnect kit to solve the problem. But since this kit only deals with the issue of linking the satellite receiver to the FM radio, I can't see where this would help.
    But it does appear to me that XM has made some kind of change in their sat broadcast that is causing this problem. (Maybe reduction in power?)
    Ant one else have a suggestion??
  • chileduck Dec 11, 2008
    I have a Delphi XM SkiFi2 which I have used problem free for 2 years. But just recently when I first turn on the car and the unit powers up, I will lose my preset station (shows "loading") and then resets to the XM channel 1. When I press one of my preset station buttons, it will again lose the signal ("loading") and takes about a minute to find the signal.
    I believe this problem coincided with the addition of the Sirius stations. I can't believe this is just a new problem with my unit and others must be having the same problem. I think it is an XM satellite problem. How would I even try to ask someone at XM radio?
  • Anonymous Dec 14, 2008
    Same thing two weeks ago. It worked fine, now "it's loading" whenever I turn it on or switch preset stations. All radios stop working when sirius comes on?!?! It's their problem not the radios.
  • rossw2221 Dec 28, 2008
    I have the same problem in my 2007 FJ crusier. Radio loses signal, blinks loading than no signal message appears.
  • jandressler Dec 28, 2008
    This happens to my in home unit only on sundays. Of course that is the time when you want to relax and listen to the music.....Every Sunday. Maybe no one is working on sundays at sirius/XM. I hate the Sirius side of things. they ruined the channel line up....
  • Anonymous Feb 09, 2009
    brand new saturn vue, xm signals not being picked up after 3 attemtps
  • Anonymous Feb 17, 2009
    Same thing happens with me, and it all started right after the merge with Sirius and the channel lineup changes. When I called Tech Support they tried to tell me to refresh the radio, which I had already done. That works, but it will happen again. Seems to happen mostly when I have any of the channels from 70 to 79 tuned in. Yes, I know that sounds bizarre.
  • Anonymous Mar 12, 2009
    happens on one of our radios (we have two on account) periodically. Usually going to XM website and eventually finding troubleshooting or something similar will lead me to "refresh radio" - which I do and this has resolved problem in the past. Takes about 15-30 minutes for channels to come back. Follow the instructions. FYI I have strong signals with antenna, but channels load for a second and then go out with loading showing. Try the refresh solution. Good luck. George
4 Related Answers
Don Reiman
  • 773 Answers
SOURCE: XM radio tunes to random station when turned on
There is an internal battery to hold the station and presets. It is probably no good. Either that or there is something very wrong with the unit.
Here is what I recommend. Call XM. Tell them your receiver is not longer functioning correctly and that you are thinking about canceling your service because you don't have a receiver. They will then offer you a receiver because they don't make much money on them, the make their money on the service.
that's how you get a new free satilite radio.
Posted on Dec 24, 2009
Anonymous
SOURCE: My xm radio stopped working in a 2009 silverado.
I am having the same exact problem in my VW 2006 TDI Jetta. This appears to not be limited to GM cars. The radio had worked flawlessly for 5 years until March 20. Only channel 0,1, 247 work. Multiple refresh signal had been sent. Although, at one point XM tech support stated that 6 signal were in cue at had not been sent due to a computer issue on their side. Still no solution. I guess I will be canceling my subscription.
Posted on Apr 29, 2010
Anonymous
SOURCE: "not ready" message on XM radio
Remove the Audio Fuse and then put it back in and the problem is solved. So frustrating that I had to find this solution on another site as both the dealer and XM had no idea how to fix it. Dealer tried to tell me it was a bad radio and I'd have to get a replacement from Hyundai.
Posted on Jul 10, 2010
Anonymous
  • 458 Answers
SOURCE: I am not getting any
XM radio broadcasts exceeds the duration of free transmition requiring subscription to acquire broadcasts. Contact an auto electrical stereo installation facility to acquire the plans available to reestablish the malfucntion. Usually, auto stereo stores provide the experiece of exploring to acquire the most appriopaite devices compartible with vehilce making installation achievable. The auto retail provides the inspection of whats already installed in the vehicle to determine the most appropiate kit to achieve XM broadcats expereices.
Posted on Feb 03, 2011
Help Audiovox Onyx
Its because of the tall buildings and all the power around you breaking the signals.
Apr 23, 2013 | Audiovox Xm Onyx Sirius Xm Satellite Radio...
XM radio ''NOT READY'' message
I have had this problem at least a half-dozen times, and the simplest solution is to pull the 2 fuses labeled 'audio 1' and 'audio 2.' It resets the radio, but it will work for a while after that (until I have to do it again). Had the xm unit replaced 3 times, new antenna installed, replaced the antenna connection wire - it always dies within a month.
Sep 24, 2009 | 2008 Hyundai Veracruz
XM radio reception issues
If you have the magnetic antenna, check it for a little nick on the cable on the outside of the car where water might get in to it. A little water can short the ground and the antenna wire. You also can wash (with lots of water around where the antenna cable is) and see if it happens again, then you will know it not just the weather
Mar 05, 2009 | XM Radio Audio Players & Recorders
Headlight problem
need to change the turn signal the power for the headlight lows is going thought that switch
Jan 19, 2009 | 1998 Toyota Corolla
Stations dropped
Go to refresh.xmradio.com and insert your radio ID and click submit, it will send a refreshed activation signal to your radio and you should have your channels back within about 15-20 minutes
Jul 15, 2008 | Delphi Roady XT XM Radio Receiver
XM Radio
My XM just recently started to cut out in certain locations that had no problem before. It seems to be getting a good signal the screen display does not cut out. I lose volume and get static just in certain spots. Anyone know where I should start looking for a fix.
Jun 26, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
XM Loading Problem for Volkswagen
I had the same issue. I called XM multiple time to have the signal resent. I told them I was receiving the preview channels and nothing else. I asked them multiple times if it could be hardware issue and they said no. I took it to the dealer and they ran a test ($98) and determined that the unit had failed. They didn't charge me for the $800 unit, but they did charge me $300 for the installation. Its working fine now.
May 26, 2008 | XM Radio Dual XMP7000 Auto In-Dash CD...
No Signal on my XM Radio
Lately I have been loosing the signal constantly in the house. I've tried different stations to see if it would be any better and it's not. I called xm and they refreshed my signal but it didn't do ant good. It's really annoying to constantly have the signal fade. Everything is hooked up right. This is been going on for about 5 months and my neighbors complain about the same thing.
Any Suggestions
Jul 30, 2007 | Audiovox XCS9 XM Radio Receiver
Car Audio & Video Logo
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
 Mikey
Mikey
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
