The laptop is 3 years old and out of warranty.
Try checking the keys in Command Prompt
Go to Start
type CMD in RUN
and type the keys and check if they work
If not go to device Manager
Steps
Click on Start
Type device Manager in Search Program and Files.
There will be a List and find Keyboard
Expand the Option
You will get the driver of Keyboard.
Right Click on it and click on uninstall.
Once uninstalled the driver will go away
Restart the PC once you reach the desktop it will automatically install the driver.
You will get the notification of driver installed.
It it installs successfully try using the keys that are not working.
Hope it helps
SOURCE: Noisy Fan in my Dell Inspiron 9300 Laptop
Get a can of compressed air used to clean computers.
Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
laptops should never be used on soft surfaces eg carpet, beds, cushions, etc. Most newer laptops also have more cooling slots / openings. this leads to a fater build up of gunks inside..
Best option is to buy a GOOD 3 fan notebook cooler.
If you are comforatble opening the laptop then that is a better option for cleaning but if not a good laptop repair shop could do this quite cheaply.
It is a common issue with newer laptops
SOURCE: i have a dell inspiron 1545 laptop and audio isn't working
1. Go to support website
http://supportapj.dell.com/support/index.aspx?c=au&l=en&s=gen
2. Click on Drivers and Downloads.
3. Click on Choose by Service Tag
4. Enter you Service Tag
5. Download the Audio Drivers and Install it after the download
SOURCE: Dell Inspiron 1545 power adapter not charging machine
Just call Dell, don't take it back to Best Buy or anything (that's where I got my Inspiron 1565). They will put you through a couple troubleshooting items and decide whether it's the AC adapter went bad or if they have to replace your motherboard. It's all free since they have a 1yr hardware warranty.
SOURCE: blank screen on my Dell Inspiron 1545
if your getting your dell logo it means your disply is working fine
may be u r windows is not working properly just try to up-date your windows with any windows disk
SOURCE: laptop dell inspiron 1545 no power up
Hello anourkhader
When was the last time you used it, and were there any problems? To find the solution to this problem is a matter of elimination. You should check the following:
Step 1 - Power
- Try an alternative power adapter
- Try plugging in your laptop to an alternative power supply
WARNING - BEFORE PROCEEDING, PLEASE FOLLOW THE FOLLOWING SAFETY PRECAUTIONS!
1. REMOVE THE POWER ADAPTER FROM YOUR LAPTOP
2. REMOVE ALL PERIPHERALS
3. WEAR A WRIST-GROUNDING STRAP, AND CONNECT IT TO AN UNPAINTED, METAL SURFACE. IF ONE IS NOT AVAILABLE, TOUCH AN UNPAINTED METAL SURFACE TO DISCHARGE ANY STATIC FROM YOUR BODY
Step 2 - Remove and reset basic hardware items
Remove and reseat the items mentioned below in the order they're mentioned:
- AC adapter
- Battery
- Memory
- Hard drive
For instructions on how to do this, please refer to your user manual. If you no longer have it, you can download it from here: http://support.dell.com/support/edocs/systems/ins1545/
If after following the above instructions, your laptop still doesn't turn on, I would recommend that you contact Dell customer support, which you can do by following this link: http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?
I hope this helps. Please feel free to contact me if you require further assistance.
ajblaj
